Intermittent Fueling Issue (Mk1 Caddy)
Points, condenser, plugs, leads, dizzy, rotor and make sure its timed properly.
hi
JonP said
Coil, make sure it is the right type for the engine, do not believe what the car shop tells you just because they can cross reference it against your reg on their system. There are types for electronic ignition and those for points. they do not mix and the wrong type will burn your points and condenser out.
hmmm the coil i just bought said not to be fitted with contact breaker points, i thought well i gave them the reg of the car it should be the right one but may be not.
May be this is why i cant get an accurate timing with the strobe light i can centre it but it skips to the left then to the right back and forth.
my carburator is manual choke but the engines revs like its got a faulty auto choke.
