Intermittent Fueling Issue (Mk1 Caddy)
(In Topic #141862)
My poor Mk1 Caddy has been off the road for the last few days due to an intermittent fueling issue.
The car starts fine and I can drive away as normal with no problems but for only a certain amount of time, sometimes its 10 meters or sometimes its 30 miles.
The Issue:
The car will be fueling as per normal and then suddenly the fuel is restricted and will start spitting, this causes the car to jump or ''kangaroo'' until it eventually stalls… When this has happened I found it impossible to drive unless i have the choke all the way out.
Like I said the issue is intermittent, I have driven 10 meters and it occurs or 30 miles and it occurs so it can't be affected by heat.
Rectifications:
I have stripped and rebuilt the carb, and also had a friend of mine adjust the fuel ratio and ignition timing on a rolling road.
I then removed and tested the lift pump to see if it holds a vacuum which it does, the arm also doesn't show signs of wear.
I have dropped the fuel tank and removed the 'what i thought was a sender pump' which turned out to be the fuel gauge.
I am a bit stumped at this point, I was thinking it may be a blockage or kink in the fuel line, but then that wouldn't be intermittent surely? :dontknow:
I'm 18 and its the first water cooled VW I have owned so any advice or other possible causes would be greatly appreciated.
Many Thanks
Dan
I had an F reg caddy and did the following.
dead points and condensor. cheap and chips and well worth looking at. probably look at the dizzy and rotor to. make sure you have the right coil fitted. caused no end of troubles with mine, i had a later electric ignition fitted rather than one for points ignition.
my last caddy had similar issues,
UPDATE:
The caddy was in absolute bits, the tank was out, carb removed etc…
I ended up just replacing parts just to rule them out, I replaced:
Condenser,
Dizzy Cap & Arm,
Vac Pipes,
Carb Flange,
Lift Pump.
All for the grand total of £42.40
But still no joy, I drove two minutes down the road and the same thing happened!
I really have no idea…
do tou have a clear fuel filter under the bonnet on the left?is it dirty?
I had the tank out today to fix the fuel gauge (as i must have put it in wrong last time :/) the tank looks quite nice and clean with minimal rust…
Does anyone have any further ideas? the fault seems to be much more regular now and is now pretty much undriveable.
Thinking fuel tank will be coming down tomorrow, even though it looks fine just to make sure I am not missing something…
Please help this is driving me and my friends nuts!! there cant be much left!
85 Karmann GTI Cabby Black Edition
81 GTI Tin Top (1.8t "The Tarmac Muncher" )
this is the thread i posted in mk1 chat, but must add it is intermittant
i have reported this problem before
the car is a clipper 1.8 with weber carb
the problem is that when going up hill and or putting your foot down to overtake the car seems to splutter and loose power but dipping the clutch and reving it seems ok, this happens when at 2500 revs and when going up hill putting your foot down or when cruising at around 50/55mph and wanting to overtake, each time the revs go up to around 3500 and then it splutters
so far from other thread i have put new
1 petrol pump
2 inline filter
3 fuel reservoir
4 service kit for weber carb, including filter
5 checked timing mechanically and electrically
6 new plugs
7 about 2000miles ago new dizzy and rotor arm
8 new plug leads
9 new rubber mount for weber carb to manifold
when i bought the car three years ago put new petrol tank and checked out the swan neck
about 500 miles ago new clutch
what can it be???????????????????? any ideas appreciated
could it be that when wanting more torque the clutch is slipping, i am ruling this out as i have been on a drive of some 100miles and no problem
Haydn
Regional Host South Wales
spitting high in the revs might be timing advance?
check the hoses going from the carb to the distributor and replace them if you can, they will be pence
failing that, maybe carb mount not sealing right? i went through 3 of these before i got one that was good enough in my 1.1…
booze and boredom, the greatest mix
with timing gun checked advance up to 2500/3000 revs
Haydn
Steve
hi
but on my old 1.5 it was the fuel tank for sure as i fitted a plastic filter and it never happened again until the filter was blocked with sand and rust i cleaned the tank out fitted new plastic disposable filter and she never did it again.
i wonder how much a new dizzy costs.
mine sparks one min then dont the next so mine isnt fuel related.
blackcherry said
any joy with this after? mine is not fuel related after listening to a mechanic saying fuel starvation or vacum leak or even carb iceing, i took the lead off from the coil after it cut out and was not sparking.
I just found this thread, I have posted a similar help thread, mechanic and I were working with it last night and it seemed to be intermitently sparking - any further clues?
