91 Clipper Cab ABF 16v-twin 45s
Ive refitted number plate in correct place as not a fan of low down ones.
Start and set up on wednesday.
Video of start up…..
http://www.youtube.com/watch?v=fKzHST7TeA8&feature=g-upl&context=G2420911AUAAAAAAAAAA
Set-up to carry out and then off for a custom stainless exhaust……..
Had an hour setting up. Now balanced and mixture seems ok at idle so hopefully be ok for exhaust fitting. Ended up having one of hubs off again as when i fitted new bearings, when tightened up jammed against circlip. The two bits that you grab with pliers were too deep when checked. So ground them down and now nice free spinning wheels.
mk1 golf - resto
mk3 polo breadie - daily banger
Ill get a video and better pics of finished item when it stops raining.
Oh and as for the first drive with the abf……..it goes like hell!!!!!
Above is link to a video with exhaust showing snorty carbs!! Still a little setting up to do. When the rain stops, ill get a better quality vid of exhaust and engine.
Also couldnt resist tag to remind me to start the fuel pump.
Ive also replaced air con water temp sensor for one that correctly operates dash gauge. New oil pressure switches fitted too.
I managed to find a bit of sun so gave her a leg stretch. Seems ok, but ill be rechecking timing and idle mixture now cars up and running.
How much did the exhaust set you back and did they fabricate the down pipe/manifold too? What profile tyres are on the splits?
Mk1 Golf floor mats - for tin top and cabriolet - Zero7796 17298Five
Exhaust was £280, manifold was separate from dub power direct.
Tyres wise, i stuck with good old 195/50s. Looked at stretching 175 or 165s but i want to use it!
Also been in for tracking and in amongst Derby traffic seemed fine.
Ill get a vid of the rolling road session and get it up later.
Wish me luck……………………………..
And arrived………….
A bit early as not open until 9, but seemed ok on the way over. Ill just see how she gets on……
Following the horrible weather on rolling road day i thought it couldnt get any worse so made a trip out to see some friends out in their campervans. On this trip i only had to navigate a flooded road near uttoxeter! Engine wise its awesome, the induction noise does it for me everytime!!!! May change suspension next as a little firm for me.
Oh…… and took the roof off!
Most have been original hood?
Can't wait to get mohair top on Gone for black but have a new grey cover so when topless will retain clipper originally (except for 2.0L 16v on twin carbs).
Hood now fitted and looks awesome. Just allowing it to settle before fitting side trims and carring out any final adjustments. Huge thanks to Carl (Chortle), hood guru. Cheers mate.
Car looks transformed……….
