Daily Driver Help!
Daily Driver Help!
i need it mate or i got no car for germany until i find another one :( selling the cabby and my 1.3 petrol i was going to sort this caddy out but its going to take longer than i thought, so i need either another caddy diesel or a golf diesel which yours is :D
if you cancel an insurance policy or let it run out, you can re-use your NCB up to 2 years after then it goes back to 0.
paul is spot on there as i found out to my horror when i stopped getting a company car and they changed it to a car alowance but you can play the system a bit.
i took my expried 2 yr NCB certificate and a letter from company saying i hadnt had accident in 5 years of driving for company and got them to start me on 7 years NCB or something like that.
i think if you go back to the insurer who last issued you the NCB ceritifcate and threaten to go elsewhere unless the consider the NCB then they would usually back down, you just had to be a pain on the phone :-)
mk2GTD sounds like it could be a plan ……
1.8T CABBY
i could hire it to you :)
just sell it me you know you want to :D and atleast you will still see it and know its being well looked after :D
i have a diesel engine you could put in the 1.3?
to much effort, engine mount in wrong place etc .. better to find a diesel
there isn't that many around really
gotta keep mine for a while as it's the only working car
buy a new one with funds from mk1
turned out the water pump broke, impella broke and the shaft bearing. Cut through 1/2 the timing belt and the timing belt cover. not far from loosing the timing belt.. that would have ment dead engine
all fixed now but not sure on cost as the bill will arrive in the post
i'll look forward to that!! :lmao:
They are Pug worth sub-1K, you need to spend £ 500-1K to get fixed, and then it does not make sense? Sale pug to buy a new motor as a spare / repair. You can get a 1K to determine the MK4 the GTI.
Don't want to be the first to cast aspersions but regarding the broken water pump, was there enough antifreeze in the engine? :dontknow:
Last year after the frost ebay was swamped with spares or repairs vehicles 'was running fine until water pump/cambelt/radiator/headgasket went' or 'it strangely over heated in freezing weather?'
yea there was plenty of anti freeze in the motor
the mecahnic was a bit stumped to why it happened
the car was 5k of a cambelt change anyway
