Won't accelerate!
Won't accelerate!
So, as far as I can understand, my fuel pump is OK.
Any tip on what I should do next?
The car runs on all four sylinders. If i push down the throttle a bit while starting, the rpm runs smoothly up like everything was OK, but then it dies. Unless I take my foot of the throttle. Then it runs like on its usuall idle.
I cant push down the throttle while its running, it just cuts out , loosing all power…. :dontknow:
This is really frustrating!
Golf California Cabriolet 1.8 GL 1988
http://clubgti.co.uk/forum/showthread.php?t=81658
Checked control pressure regulator today. My gauge jumped immidiately up to about 4.5 bar. ShouldŽnt it rise slowly to about 1,5 bar?
Thing is, when I started testing, the engine was working perfectly! Hmm.
I had a fuel leak on my gauge, and a small stream of fuel was leaking out. But when I sealed it, the enginge immediately lost its power again.
So maybe its getting to much pressure.
I tried to clean my Control Pressure Regulator, it was some dirt and rust in it. But it didnt help.
Also I checked the terminals on it, and they had no resistance….
Does this mean I need a new CPR? ( or is it called WUR?)
AND, any tip on where I could get a used one? Do i have to find a Golf with the exact same engine, or not?
Thanks so much for helping me out here.
Thanks for the thread too. Also been reading this one a lot
The Bad Habit Rabbit - Volkswagen Rabbit Page - Fuel Pressure Gauge
Best regards
k-jetfactorymanual.pdf - Google Drive
https://docs.google.com/file/d/0B_V9-6xfgGlIY2M3M2I2OTctOWExOS00YWJlLWJlMzctZmNkMzI1NDJkYmNj/edit
May I ask,
is it supposed to be a vacuum line attached on the WUR? (If my picture works, its where IŽm pointing)
The terminals has no resitance. Can a good electrician fix it, or is it a lost case?
Thanks again for sharing your knowlege, rubjonny!
repairing the heater inside the WUR wont help much as the pressure will still be all wrong, all the plug does is heat the wur up a bit in addition to the engine heat. it wont make it instantly open to 4.5bar.
if you open it up though you might find something obvious that is fixable, but personaly i would just get another one
But still, the pressure is about 5,5 /6 bar. Which is the same as the system pressure. Could there be something other than the WUR that is blocking the return fuel and making the pressure that high?
Might also mention after turning the engine off, my controll pressure drops from 5,5 to 3,5 and then it uses , IŽd say hours, before going to 0 bar.
IŽve taken the fuel lines to the WUR and cleaned them. When I checked the fuel delivery, I got ALOT of fuel out from the return line to tank. (My 0.8litre cup was full in 20 seconds).
Metrering head. Thats worse, isnŽit ?
The car has always had a hot start problem and also it has had some poor acceleration…
Some usual problems? I only know the sensor plate moves smoothly…
I dont have much knowlege about my new WUR. Only the word from its seller. I will open it now and clean it…
Can I test the WUR by taking the return fuel line to metering head off and check its delivery rate? Would that give any awnsers?
Again, thanks so much for your help!
It works!
The WUR I bought was full of dirt. Cleaned it very good and then I got my 1.5 bar fuel pressure.
I noticed that there where a diffrent kind terminal on my two WURs. The old one has a restistance of 12 ohm and my new one has 24ohm. The old one has two "resistors" inside, one with 20ohm and one with 30ohm. They are wired in parallel, so 12ohm is the correct value. However, is it ok to use the 24ohm WUR?
Cheers :wink:
Thanks so much Rubjonny. You saved my car from the scrapyard!
Best Regards
Aasmund
