Golf PD TDI Cabby
Re: No veggie oil!
Golf PD TDI Cabby
Normally yes but the older stuff I.e early td stuff and non turbo diesels, mk1 diesels should be fineallana13 said
bluey12 said
Hi Bert, my advise would be to stay away from the veggie oil. I'm a technician and we have recently changed a few 130 pd lumps down to the veggie oil reacting and turning oil to a sludge on one occasion. Looks amazing though should be very fast with lots of torquessss!Bert said
vegetable oil can be used,it states so im my passat owners manual,i wouldnt like to add much though,the electric pump in the tank wont like it :wink:
Bert
Its ok for older cars though ???
got the garage cleaned up a bit today,bolted the cabby to the rollover jig so ready to spin it over and sort out the underside,took the gearbox off the engine,need to sort out a gearbox as the polo 02R has no speedo drive and odd drive flanges,so need to source a good box to use,was going to try a AAZ 020 100mm box on see how it fits? its just the worry that a 020 box and a 210mm clutch will hold up?
Bert
Bert said
small update,polo now stripped,and shell weighed in,kept everything any good off the car,
Bert
1.9 TDI box from a 1Z or AHU engine fitted to mk3 golf or seat ibiza/cordoba would be the best bet, they run on 90bhp so would be better than an AAZ box, also good if you want to avoid custom drive shafts and gear box mounts.
hows the wiring getting along fella,
ive got my mk4 golf tdi donor car back at the garage now, dont really want to start pulling it apart until i know what im doing with the wiring side of things.
didnt fance a 020 incase the clutch wont hold out
Wiring ready,just need to get it fitted and see how it goes :wink:
Bert
A o2a is the best bet as the mounts are easy to make or get and a g60 clutch fit well and is very strong.
could you please pm me a spec of the wiring as im going to get started on mine soon and i dont know where to start any pics would help massivley
cheers azza
foxy
foxy
azzatdi said
bert dont use a aaz box as it wont hold and it will just blow everytime you floor it!
cheers azza
Some wiring diagrams would also helpe out alot too.
If you could also pm me with the specs it would be greatly appreciated
Bert
Any pics on the wiring?
Petrols are fine for aaz box's because of the torque
Azza
dub_fatha said
Guess i will have to figure out the wiring myself then!
really look what rubjonny said under your 1st comment and if you ask the question in modification bit he will prob help you more
really love this thread got me thinking about diesel power now plus all that cheap veg oil
It dunt fit
read this thread though its mk1 abf but for the wiring involved the mk3 tdi is pretty much same:
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=113764
ignore the later part of the tread where he finds 2 fuseboxes though just concentrate on the bits where i explain how to splice the mk3 loom to mk1 fusebox.
tdi maybe even easier as no coil modification to worry about. you'll need to put the DBW pedal plug behind the fusebox and extend the wiring from where you mount the DBW unit to it, but thats not hard cut, add length and done
my donor is a mk4 tdi matey :dontknow:
ive done plenty of mk3 engine swaps so know the wiring very well on the 1Z and AHU conversions, but have never done a mk4 swap before
http://www.clubgti.co.uk/forum/showthread.php?t=205887
rubjonny said
ah ok well read this thread for 1.8t wiring into mk2, near the end i cover CE1 mk4 wiring conversion with details on how i do the wire routing. mk4 diesel will be very similar:
john, you are the man.
many thanks for the link
Got the paint out and made a start on the rear wheel arch whilst the suspension is off,tidy it up a bit,this is the first coat,covers well
then the front was stripped ready for paint
Engine/gearbox wise im going to use the 02R polo tdi box,i managed to get a set of 100mm flanges to replace the 108mm ones currently fitted to it,
Also removed the dual mass flywheel and clutch and got a g60 solid flywheel and clutch for it,old one
new one
Also got a genuine timing belt kit ready to go on when the water pump is purchased 8)
Bert
