Lower bonnet catch
(In Topic #139493)
Lower bonnet catch
They only seem to have them listed for the mk2 on vw heritage..
Drive like you mean it!
On eBay, type in Vw golf mk1 bonnet and chubnut99 is selling one
I would have put up the link but on my iPhone and can't get it to work on the iPhone eBay app
Cheers chris
Tom
edit: post 83 cab does use the mk2 LHD bonnet catch though, so it might possibly fit the tintop/early cab
looking at it though the upper catch on the bonnet is different pre/post 84 cabby too so im thinking if you want the lhd mk2 lower catch you also need the upper catch to match it! and lhd/rhd upper catch is different too for some reason
Im sorry if thats my fault :redfaced:
I got that one I said for my cab but my prob was that I never realised that the upper catch was a mk2 one and bought 2 mk1 uppers before I realised there was 2 different ones.
The upper on my cab has the spring on the right and the earlier mk1 had the spring on the left, so I found out it was a mk2 upper that I needed.
I dont know why there are so many permatations :dontknow:
Chris
I've compared my old catch to the pic on the vw heritage website and they look the same..
I guess ill just wait and see what turns up!
Yeah you would have thought they'd all be the same!
Thanks for your help,
Tom
http://www.vwheritage.com/vw_spares_Bonnet-catch-upper-Mk2-LHD-Cabrio-RHD-84_act_shop.product_pID_48416341_lang_EN_country_GB.htm
lower catch, again note post-84 RHD cab and LHD mk2:
http://www.vwheritage.com/vw_spares_Bonnet-catch-lower-MK2-LHD-Cabrio-84-RHD_act_shop.product_pID_48416497_lang_EN_country_GB.htm
RHD MK2:
http://www.vwheritage.com/vw_spares_Bonnet-catch-lower-G2_act_shop.product_pID_45367_lang_EN_country_GB.htm
plus note the part numbers. 191 = LHD or non side specific part, 192 = RHD specific part. But I'm pretty sure if you buy the late cab/mk2 lhd upper catch as well the lhd mk2/late cab lower catch will work with it
I've ordered the RHD lower catch and the new upper catch i have has the spring on the right, opposite to the one in the link..
Only difference is the old one has a pinch bolt there the cable goes in but the new one needs a bit attached to the cable itself..
Sure i have something off my old bmx brake setup that will do the job
Although it looks the same, the 4 holes in the catch itself wont line up with the slam panel unless its in the wrong way round! Ya can see in the pics.. :dontknow:
So i need to swap them for these..?
you'll probably need the later bonnet release cable too, funnily enough its the same as a mk2 golf RHD cable so thats handy.
the post-84 handle is same as a MK2 Golf RHD one too. Karman been raiding the MK2 parts bins
edit: actually, that could be a problem. i cant see how the rhd mk2 bonnet handle could fit on the passenger side so im guessing from 1984 the handle is on the driver side in RHD cars? if so hmm not sure if the later cab parts will work unless you also get LHD post-84 cab cable n handle… unless the old cable is easily modified to work with the mk2 catch or the mk2 cable fits the old mk1 release handle?
So those parts will be fine? It just depends on the handle and cable?
Will the catch be for a non adjustable cable like the one i have already got? I should be able to mod that pretty easy
the mk2 bonnet cables just have liek a ball on the end of the cable that slots into the catch, so its just worst case you need to change the cable end to make it fit. something like a bike brake cable end crimped on should do
Have you by any chance found out how to easily mod the cable end? I have the early tintop golf with the cable running along the passenger side of the car and the cable ends without a ball…
from your investigations, could you please clarify which lower bonnet catch has the crimp bolt and which requires the ball at the end of the cable?
Thanks very much (sorry if this is a thread hijack)…. hope yours is sorted.
1980 Series 1 GTI (gone now .. what a mistake selling her!)
1979 Series 1 LD - the Mandarin Dragon … gone as well. oh dear.
