Help with newly fitted hood/window seal
Shame you did loads to the blue cabby I saw your thread on it too. You not getting another Cabby then, or have you plenty of projects on the go?
I know where it is right now its owned buy the guy who runs the mot place i take my golf to, currently awaiting a respray. god knows when he'll do it though. If i had somewhere to store it id buy it back!
Jut seen the bit about the little gap, between the seals.
You will need to adjust them to get the best fit, sliding them backwards and forwards. Also when he fitted the foam gaskets, he probably didn't leave an overlap either end. this folds up and onto the seal ends to take the space up.
Also the sillicone needs applying to opening of the rear window before the seal and glass goes back in, as well as the outside edge as Johnny pointed out.
chortle
had the step by step guide running on the laptop was not as hard as it looks
Keiron foster Forever Fund for Meningitis UKxxx jen xxx
Proper shame, hope he manges to get some redress out of the fitter.
He is probably aguing with them now as we speak.
hope he gets it sorted
Problem is, I've been hunting around for non-setting mastic and can't seem to find any. Can someone recommend a brand/shop where I can get some? Or will any black silicone sealant do?
the toy: 1990 VW Golf MkI 1.8 Cabrio Clipper
daily driver: 2011 BMW 120d M-Sport
It's in a tube use for sealant gun.
It says roof and gutter sealant on it though.
Make sure you run a strip of masking tape under so you don't get it all over the paint work.
Chortle
