MFA battery etc, blank MFA Clock
the fuse holder above the fusebox with the grey/white wires is the rear fog light fuse in case you didnt know, so switch lights + fogs on and see if you get 12v to the back of the fuse
I need to drop it down and have a proper look.
I reckon having a 30 A in has damaged the box if thats possible.
Will have another look tomorow.
cheers again.
chortle
If I short the pins in the brake fluid level sensor cap, that should rule out hand brake switch problem?
Is that about right?
Just trying to rule a couple of things out.
Checked pin 2 Earth and it checks out Okay
Checked pin 4 IGN ON and I get just over 12V
So they seem okay.
I have checked the wire from the stalk assembley that connects to the Black horn push, followed the BRN/BL to plug L and it checks okay.
Hmmm most perplexing.
will check the fuse and bulb tomorow but think that has been disconnected, will trace it back from the switch.
fusebox is 171 941 821 D, available from VW classic parts for €165.01
No clicking, the relay No6 is brand new as it was missing originally.
Fog light switch does illuminate, with lights on. It's illuminated 2 clicks on.
So there is power to the switch.
Its wierd though as yesterday I had no earth to the bay from the column. So I am gonna make a new wire up from the bulk head to the rack in case it's intermittent. It checked out okay before.
At least I know I have supply and earth at the fuse box, jut something missing in between.
So need to get another.
Thanks so far
Chortle
if the light comes on then power should be coming out the switch, just a case of follow the grey/white to the fuse holder, then from there to the light.
I had Ross come over to cast an eye and see if he could shed some light on it.
What had happened was when I went into the motor factors I picked up the wrong relay from the right place in the rack.
So it's pin out was different, teach me to look properly.
Luckily Ross had another spare so once that was in all was well.
Fog light dirty contacts in the bulb holder sorted.
Warning light handbrake switch switch needs replacing.
The seats heating plugs were disconnected.
Once the seats were upturned all the realay and wiring harness bits were missing.
Gutted as these willl be a pig to find unless I get hold of the bloke in Canada the other forum users have used.
We noted that the plugs from the loom to the seats plugs were identical male and female connectors.
We checked for supply and all was good even varying it with the heated seat controlls on the dash.
I explained to Ross the missing bits the other guy's have on their heated seats, so a quick check around revealed that VW had moved the both relays position to my fuse box, Which was relay No 57. Plugging the connectors together and turning up the control dial resulted in the drivers seat at least warming up. I had taken the Passenger one out so I could get better acsess to the fusebox.
So will return that to the car tomorow and hope it works too.
Ross took the clocks out and tested the RED wire to MFA and it has supply, so the module is probably busted, or a faulty earth.
So a bit more checking, but have a spare set of clocks coming to go in.
So still a few more bit's to sort out though.
Chortle
vw moved the relays around!
mk1 & mk2: relays on fusebox
mk3: relay under seats
corrado: relay behind quarter card
I need glasses.
My mates MK3 has them under his seat.
Good old VW keeping us on our toes.
just need to find a set of twin horns with the later plug on them.
Went to the scrappies today and got a handbrake switch out of a MK2, so that's another job done.
Ordered some Bembro Hubs.
Need some top mounts, seen some Febi on E Bay. Just put a post up as from memory someone had an issue.
Looking round for a sonnerland material hood, bit more durable than standard Mohair.
Next one for you power hood don't work LOL.
cheers again.
chortle
obviously check the fluid level, and if you can hear the pump run but no movement its probably the impeller on the pump that has split, a common problem and im sure i read on here somewhere there was a repair kit? if not i saw a thread where someone repaired their impeller with 2 part epoxy gluie plus a sheet of metal stuck in it (the pump has a flat keyed side which wears, so you stick in a flat bit of metal to repair the key, if that makes sence)
Just need to see if there is a feed to the Pump motor.
I can get a repair kit for the pump also.
I think I have a leaky ram on the driver side as it's soggy.
But nothing suprises me about this car.
Jelly did the engine flush and oil filter and change and got me an airfilter.
I went to fit that and there was not one in the car, it was missing. Lol.
So it's a case of having a look see.
The resevoir looks empty too. I know these can crack around the mounting points and leak too.
it's all good fun and I am getting on with bits and pieces.
thanks for your assistence so far.
chortle
Heated seat relays: under each seat.
*If not in this location it is mounted to the driver's side fender
**If not in this location, there are two interlock relays mounted to the back side of the kneebar.
