2.0 ABF bottom end and 16V KR head rebuild Pic heavy
the thinner stud is for the late abf self-tensioning tensioner, the thicker stud is for early abf and kr solid tensioner
Engine
Engine
Engine.
I managed to get a timing belt that seems to fit ok, the tensioner that came with it is the same as the KR tensioner with the slightly wider stud hole through the middle. I went for the ABL kit instead of the ABL belt and KR pulley even tho they seem to be the same. I wanted to get it fitted tonight but I've lost the bloody nut for the tensioner :-(
I put a new rocker cover gasket on this morning and the D shaped bunges (blue rubber things on the rocker, see pic)that i was on about came with the rocker cover kit. I mached the ports up on the inlet manifold to the inlet ports as there was a big lip, hopefully this will smooth the airflow out a little. I noticed the gasket between the two sections of inlet manifold (round ones) where alot smaller than the actual inlet. Would it be wise to trim these out to match the inlet diameter? I've put the new spark plugs in that GSF provided but i'm worried they're the wrong type of plug. The plugs that have been removed have 3 prongs and the new ones have one. I've not looked into what temp they are yet.
I'm going to steam clean the alternator brackets, auxiliary pulleys and timing belt cover tomorrow before I fit them as it would be madness to fit greasy parts to a nice clean engine.
While I was at GSF I picked up some new injector seals and a new thermostat too. May aswell do the job right.
I even drilled the airbox a little more ;-)
Hopefully I'll have the old KR engine out in the next day or too and my nice new one in.
abf does indeed use single prong spark plugs, it makes no difference as long as they're the correct spec, the 3 prog ones just last a bit longer is all!
8v tensioner nut will fit
Engine
Does the timing belt tensioner turn clockwise to add tension?
Thanks?
Engine
KR engine.
KR engine on it's way out.
KR engine now out.
Next job is to get the engine mount on the ABF block and all the belt covers, alt brackets and alt and the aux belt. Then i'll get my upgraded clutch, lighter fly and new box off the KR engine and swap them onto my ABF.
I'm deffo going to put the knock sensors and brackets on as I may swap to the ABF fuel system later in life.
Engine bay
Engine build
Engine
New thermostat and pipe work
Engine
I was looking on my auto data software and it suggests that 20nm is the torque setting for the sump bolts. Is this correct as they kept snapping at 20nm unless my torque wrench has packed up.
Engine
Engine
This evening i fitted a new sump gasket, timing belt cover, flywheel, clutch, gearbox, pulleys, belt and started.
Plan for tomorrow night is to drop the engine into the car.
