2.0 ABF bottom end and 16V KR head rebuild Pic heavy
rubjonny said
ya but 02a flywheel cant be used with 020 gerarbox. if you want 02a gearbox you have no choice but to use an 02a flywheel. so as i say, its not a weight choice, its becasue you have to match it to the box!
Not in my case as I had the two different gearboxes, the one from the KR and the one from the 9A, in my case it was a weight choice
Yes but did you choose the flywheel you fancied, based on its weight, then that dictated which gearbox you'd use, or the other way round? Its worth mentioning that the 020 box is about half as heavy as an 02A box anyway, and you don't have all the hassles with adapting a hydraulic clutch and cable change linkage. But an 02A box is likely to be newer and better condition, and doesn't possess a couple of design weaknesses that the 020 has.
Honestly chose the lighter flywheel as this is critical to have a "happy" engine, the 9A is too heavy for any performance car with 140HP, now if you have 250HP you'd better go for the heavy one.
The hydraulic system is not so difficult to swap, there are already some pieces designed for it on ebay…
Flywheel
Parts
The ABF lump?
GSF don't do them and the dealer charges the earth.
What is your opinion?
Loom ECU
yeah ignore any figures stated by the seller, usually the very best case scenario and 'special' rollers that lie.
my own abf got +6 bhp and +5 torques with a chip, dyno proven back to back
Loom
I've just got some bits together from GSF today and they have sent me a ABF head gasket/top end kit. I wanted a KR top end kit and a separate ABF head gasket kit or is the abf stem seals, exhaust gasket and inlet gasket etc the same as the KR .
Don't worry, I'm nearly at the build thread stage ;-)
I could do with one of these looms matey. Could you pm me some details? I could do with getting it done ASAP as it's stored in my parents garage and I need to get it out of his way before Xmas ;-)
with the loom xmas isnt going to be doable i have 13 looms in now
as i say though if you need it quicksmart i can take you through it all
Wiring loom
I've had a read on other threads about this and it does seem a little bit more than I can chew but I'm up for a challenge.
I trust it's just a case of extending the leng of the wires and figuring out which pin on the fuse box is to which pin on the mk3 loom plug then cutting the mk3 plug off and replace the mk2 plug.
Is the mk1 fuel pump ok for the ABF fuel pressure.
I don't have an airbox or air pipe so is their an airflow meter that I'll need?
It may be easier just to use the mk2 KR fuelling until you have time to make a loom up?
finally i splice mk1/2 TCI & coil wiring to the abf ecu so the mk3 coil can be binned as its so unreliable. plus the rev counter will work without any fuss too.
you will need a mk3 inlet pipe plus an aftermarket cone filter, try to get an abf specific one so it has a hole for the inlet temp sensor.
kjet main pump is fine for the abf, but you can bin the accumulator. i would convert the k-jet pump to take push fit fuel lines, you can buy barbed adaptor off ebay for £5, you want an m12x1.5 fitting.
even if you go kr you will still need to make a loom for it, though it is a bit easier than doing an abf one.
ABF - kr
The engine that I have removed is a 1.8 16v KR.
It might be easier for me to just swap the bottom ends over and use the original fuel system and KR head.?
Is there a big difference in power between these two engines?
