'Monkeys RS Turbo
Marketing Manager
Uncle forgot to put the tractors handbrake on and it ended up backing into the car whilst it was up on the jack, luckily all that happened is the tyre rubbed on the back bumper a bit and scuffed some paint…
Got a quick snap of the car
Fitted the turbo
Luckily checked the water lines to the turbo before fitting, found this in one of them
New front pipe ready to fit, loads less restrictive than the old carp…
Oh and when I was taking the dash surrounds off to change the dash clocks and fit the gauges I found this
And got the engine built back up
Turbo is perfect, no smoking whatsoever but the bigger turbines have made it pretty laggy, turbo kicks in around 3500rpm as opposed to around 25-700 the old one used to kick in. When I was adjusting the wastegate actuator the rod sheared so had to get that welded up for me, it's running 0.6bar @ the turbo just until its all bedded in nicely then I'll turn the boost up to around .85 bar, doesn't sound like much but when the old turbo was on just under 1 bar of boost it felt pretty similiar to how the car is right now.
Off to Nicosia again tomorrow to pick up the rest of the exhaust system and the door cards, ill try and get the wideband O2 sensor wired up sometime this week and fit the rest of the zorst on at the same time.
1973 BMW 3.0CS "Helga"
1981 VW Golf GTi "Agolf"
1986 Ford Escort RS Turbo S2
1987 BMW M535i - 'Klaus'
Instagram: @ahmet_e9
Marketing Manager
Nosmonkey said
Yes mate, gaskets are all on the car, thanks a bunch for them
No worries dude glad they went to a good home. Don't go blowing it up now
Marketing Manager
Nosmonkey said
Only thing that blows in this car is the turbo and the beyatches in the back
Marketing Manager
Repairable or should I just get a new tank?
Marketing Manager
My mates 20VT mk2 couldn't get away from me when we both booted it aswell so that's a bonus
Ditched the standalone manual boost controller and opened up the boost solenoid, enlarged the two nylon bushings inside to allow the car to run 1 bar of boost, although it was a bit of trial and error of drilling, refitting testing and repeating until desired boost. Bit of a pain but I've wired up an LED and a switch up to the solenoid. When the car is on 1 bar boost, the switch is closed and the LED is on, when the circuit is broken (i.e. the switch is pressed) LED goes off and maximum boost drops down to around .5bar. With this system it also means the ECU can cut the boost and retard the timing if the inlet temps go silly high.
After that I wasn't really happy with how laggy the car was, Dropping into 4th at 50 and the turbo just couldn't spool that quickly. After a bit of fettling, I fitted the MBC back on between the wastegate actuator and boost solenoid. As it's a ball/spring type as opposed to a standard bleed valve it does help a fair bit with lag as it stops the wastegate from opening prematurely, as it's a standard WG it starts to open around 4psi and is fully open around 7. With the MBC set to 7psi turbo response is much better now, I've also made a cut out in the dash for connecting the wideband sensor to the laptop, if I decide to go for standalone management and EFi it also allows me to monitor boost levels, AFR, rpm and a bunch more data from the ECU on the laptop
I've got a couple more pictures somewhere, once I get round to sorting all my clothes and whatnot out i'll stick them up here for you lot
Marketing Manager
Got a new Payen head gasket and cylinder head rebuild kit so I can finish off the uprated head. Cut back the valve guides and smoothed around the throat of the valves to help flow a bit better. With the race profile cam, cooler and all the other work, I should be hoping to see about 220-30ish. Going to try and get an MF2 box to run a fifth injector on the cold start injector port. Don't need it as the car will never be run in cold temps anyway.
Next on the list is to source some st220 300mm discs and calipers when funds allow, want to sort the shocks out but even on standard shocks it can barely get into the underground storage bit
Marketing Manager
Picked up some Mk3 Mondeo ST220 calipers for 30 notes delivered. Bolt straight onto mk4 scrote hubs (albeit with a 12mm spacer to align the disc with the pads) and then it's simply a case of fitting some Focus ST170 300mm discs and sorted. Need 16's ideally to clear the calipers but you can grind them down a bit for standard wheels, looks pretty badass too with standard alloys
Marketing Manager
Hairyarse said
Tidy - sounds like you're good at sniffing out a bargain
It's in my heritage to sniff out bargains. I'll throw in a carpet and a kebab too if needs be to sweeten the deal
Marketing Manager
Going to grab myself a carbon skinning kit sometime this month, see if I can make some goodies
