MK1 Golf GTi 16v Power
(In Topic #137229)
I've just been and bought a mk1 with a 1.8 16v engine.. KR?
Any way it runs and sounds great but i was majorly disappointed with its power delivery.
It's not very fast, i thought it would have been much quicker. I use a Renault Clio Sport 172 on a daily basis so could this be the reason i am disappointed? Maybe my Clio is much quicker?
Just wondering the kind of HP, Torque, 0-60, 0-100 you guys may be getting from your 16v's?
I believe the only mod is the 4 branch manifold and full ss exhaust. Otherwise it is a well serviced standard engine.
Are there any mods i can do?
I'll try and add some pictures if you like.
MK1 83 Jetta… 2ltr 16v ACE
MK1 88 caddy pickup 20VT soon
MK2 Golf 90spec 2ltr ABF coming soon
T5 TDI
T5 TDI
For best acceleration, a lightened flywheel is worth looking at although of course, it can't achieve an actual power gain, but the way the car accelerates is better due to less rotational inertia needed to spin up the flywheel.
Thanks for that, that info is very useful!
I've only ever tampered with the 8v engines so your advice is excellent.
I've timed my 0-60 on the Clio to be around 6.5 seconds or so. I think it has about 160bhp per ton. 200Nm 148 lb ft. (I think)
The Clio is a quick car to be honest but I would have thought the Golf would have been close or quicker.
Maybe it is just not set up right or just the modern tech has an advantage.
I will certainly have a look at your tips tho
mk1
Mk1
Mk1
Thanks.
machine said
That video's pretty good but it blindly assumes the right control pressure is 3.4bar. The point of the WUR mod is that you can tweak this to achieve an AFR of about 13.0 during wide open throttle running, thus giving more power - but to measure this, you need to use a lambda probe. The control pressure directly influences this, and is adjusted to achieve it, its in the region of 3.4bar but could easily be something slightly different for your engine (fine tolerances on metering head and injectors).
machine said
I think my best bet would be take it to a rolling road station and have it tuned up on there when I've serviced it and change the cam belt. I've been told John Lamb in Clowne which is not from me in South Yorkshire is ver experienced in tuning all makes of car especially the older type. Does anyone else have any feed back for his services?
Ive heard mixed reviews of lambs, Try Noble Motorsport in chesterfield - thats where I took mine, did a fantastic job, and only 15min further for you than lambs
Would any of you recommend drilling the airbox and fitting one of those powerroar ss pipes as I have these also.
Its seems pretty quick, keeps up with most type r stuff, supercharged minis (beats them lol!), so i'm guessing between 6 and 7 seconds to 60mph.
Just sounds like it need setting up really, and the WUR tweek will help to :wink:
I have the old k star tuning box to fit to mine (from a turbo-technics mk2 16v), this will allow the fuel pressure on the warm up reg to be changed thoughtout the rev range to suit
Oh and I have a drilled air box to, probably get a bit more airflow, but the best bit is the noise :mrgreen: And ive also got a s/s roar pipe, but just for looks really.
At the moment tho my Clio would demolish the mk1, my 8v feels like it has more pull. Should the 16v have a burst of power that you can feel at a certain rpm. My Clio after 4500 rpm comes alive, mk1 8v comes alive at around 5,000rpm but the 16v feels smooth/lame all the way through the rev range in all gears. The other two are like type r's in their power bands haha. I thought about new performance cams and a better exhaust but it's still got a standard head so I can't see the point.
