1983 5 door 1.1 formel E resto and engine swap!
Il pop down Friday and see if there's any progress
Mat
My New Year's resolutions are: 1. Stop making lists. B. Be more consistent. 7. Learn to count.
But thanks
Mat
Hit the first of many problems, the 02j box I have has 108 mm drive flanges on it, not 100mm as I need. Does anyone have any ideas what box I need to take the flanges off that will fit my box but are 100mm??
Mat
new seats
still need some 100mm drive flanges
mat
also does anyone know if the gearbox from a mk2 16v gti has the correct 100mm drive flanges to swap into a 02j box?
mat
ive spoken with the garage today and there hoping to have the mount moved and the engine sat in towards the end of the week
mat
And for anyone thinking of converting a small block to a big block the mounts ARE different despite what some internet based numpties will have you believe. yes you can use the small block mount, but its pikey!
mat
theyve been busy fitting new pedal box and the such, waiting on a couple of bits for the engine then it can go back in for good. then the hard bit starts
mat
Don't get much sump clearance do you :-/
Pics to follow
Mat
not even a pop can worth of clearance
ignore the oil, the filter was off and its just what ran down
mat
