Elvis - My 1.8T Build - No more time wasting!!!
Ade, Yes definately up for some head to heads at the pod and yes you're right, its the second time you've challenged me haha!! Let me know if you manage to get hold of Richard too!
It sure is about time i got some work done on this Foxy, now the wedding is out of the way i can.
Finally finished the r/disc conversion today woohooooo!!! Such a pita that the car is 20miles away from where i live but unfortunately the husband is hogging the garage with his project lol
Gonna get back up there next weekend and clean all the underside and then either paint it green or just waxoyl it, we'll see. Better get my wire brush and thinners out haha!
I saw a crinkly peanut tomorrow
I'm planning on getting alot of the bits n bobs finished off while its here such as putting the clutch and flywheel in and getting the driveshafts and cv joints all together, we just wanted to get the engine in and get the wiring done and then we could concentrate on all this building up
I'll also be finishing off the brakes nd starting on the cooling and fuelling systems!
Had a pressie from Burton Power in the week too….
More pics to follow next week :mrgreen:
Nostalgia isn't what it used to be.
Been let down yet again!!! Was supposed to be getting Elvis recovered home last night but miraculously half an hour before being picked up the recovery truck broke down lol!!
Its sorted now though, getting one of my reliable guys from work to pick it up next weekend for me.
Its a p.i.t.a but never mind
Steff x
Elvis is at home now Got him back on saturday afternoon thanks to one of our wonderful guys from work and his trusty wagon!
Started to make up all the copper brake pipes on sunday, which we'll then take off and re-make in the green factory stuff (£7per metre from Ford) as i think the copper looks a bit poop.
Also started looking into mounting the fluid reservoirs in the engine bay, in the scuttle panel/tray thingy. Made a template, just need to find some suitable metal now then i can get all the brake stuff done.
Ordered some more bits and bobs from Burton Power on monday so just waiting for those to turn up
Oh yeah, Also fitted the goodridge stainless flexi hoses too
Will update when I can
Steff
Website Manager
My brake fittings turned up today so hoping to get out in the garage tomorrow night and over the weekend to get more stuff done.
Thanks for the info Ade!
how's this getting on?
MK1 Golf - 1.3l Driver
MK1 Golf - 1.8 GTI (Build Thread - Here)
Engine has been back out and we've put the clutch and flywheel back in, and chopped down the alternator bracket as i wont be needing most of it.
Got my wheel bearings to put in and build the driveshafts up and get it all put back in the engine bay.
One thing i've noticed though is that my manifold is no good. doh!!! the way the turbo is sitting means that theres a massive strut top in the way of any air intake so luckily a friend of mine is going to fabricate me a new manifold from scratch, He's coming tomorrow to measure up for it
Engine has just gone back in this evening!
As for the rocker cover, its not crackle, its B&Q 'Stone Effect' spray paint with satin black over the top of it! :mrgreen:
Wound the coilovers down at the front aswell, its on its bottom and looking goooooood! :mrgreen:
Pics will follow….
Website Manager
Quick question, what did you use to mount your fluid reservoirs?
Steff
Website Manager
Well I originally bought a floor mounted pedal box from OBP.
Tried to fit it and didn't like the pedal positions, so sold it on, accept for the reservoirs and mounting bracket. It is stainless steel and you can buy it on its own.
http://www.obpltd.com/…/3-hole-reservoir-bracket
I made up a wedge and then bolted it to the scuttle.
Anyway, think its time for an update
After looking at this….
And having an 'oh s**t' moment! I realised that the turbo on that manifold wasn't going to work because theres nowhere for the air intake to go as there's a big strut top in the way, or even if I was to turn the turbo it would be near impossible to route an exhaust down the back of there! So I called in a friend of mine who's handy with a tig welder to possibly make up a new manifold for me in stainless which would move the flange more towards the n/s of the engine, that way I could turn the turbo back around, move it over and have plenty of room to route the exhaust…..
So it began!
I bought 2 90degree bends from JP Exhausts in Macclesfield and my friend got the plate cut to match the manifold gasket, then the welding began
The finished manifold…
I bought all the studs and nuts this week so gave it a trial fit today…
Cut all the studs down to fit and got it on the engine…
Plenty of room to route the exhaust now….
Pain in the arse water/heater pipes need to be re-routed! (I've now taken them off!)
And then it came back off to turn the core of the turbo and get the compressor housing in the position I want it and took the actuator off the bracket that's been welded to the housing and repositioned that.
Its back off to Dave's tomorrow as he needs to level the manifold flange as it seems its distorted when it was welded so isn't fitting flush with the turbo.
And then on Tuesday its off to CR Turbo's for them to sort out a bracket for the actuator and clean up the weld off the compressor housing.
And one last pic for today….
Bought this shallow sump from PSI Tuning Will be getting that fitted next while the Turbo is away!
That's all for now!
started about the same time as mine i think !!!
amazing how long they take, but your is looking awesome
But thanks for the comment, really appreciate it makes it worthwhile lol
Steff
