polo gt engine rebuild
polo gt
so obviously this makes it n ADX engine but what cc is that??
if it is a 1.3 is it a lower compression than the gt block
if so could i put the gt pistons and rods onto the ADX crank to up the compression back to the gt ??
thanks for help
cant find any numbers that match so i dont think gt internals are going to fit
I'm no expert though so you never know!but I checked pistons, rings, crank, block, gasket, head etc all different numbers
polo gt
and to use the non gt bottom end with just putting the gt head and box to it, im going to be losing out on the torque/power from not having the gt bottom end?
personally id just get a 1.4 ABD bottom end out of a mk3 golf if i was going to all the effort of an engine swap.
i'll see if i can find any details on the compression etc of this engine though
polo gt
what sort of years am i looking at for the ABD and was it only in the mk3 golf or was it other varients
cheers again
91-95 golf/vento
94-95 cordoba
93-95 ibiza
might be ok to use the later blocks actually i think problem is on mk2/3 polos they need a certain block configuration and this changed later on? maybe mk1 needs the same but im not sure! as you can tell im hardly a smallblock expert im afraid
polo gt
do you know of any insides that i could replace mine with such as the crank and bearings, thats all i need
would i be able to buy a new crank and bearing set from anywhere?
supose VW would have stopped making things a week old as usual
1. Standard Mk1 Golf 1.3 engine. Might be hard to find a good condition one now. Might need to adapt or revert things back to standard
2. Proper Polo GT engine. Since your car's engine conversion isn't one of these, you might need to adapt more stuff, etc as in 1
3. Search around for a direct replacement of yours. This makes the install simple (if everything in the engine conversion was done right) but limits your choices
4. Use some other small block engine. Once again, adaption may be necessary.
I can't see the point of doing an engine conversion and the resulting one being 55bhp, but it makes a lot of sense to adapt a newer engine which has more power, if the adaptions aren't too onerous.
polo gt
the problem i have with it is thats its done 110 thousand miles and not been treated very well so is sounding a bit sick especially when pressing the clutch…this has all been narrowed down to play in the crank and big ends
i cant be arsed naffing about with 1.4 block for the sake of some crank bearings and re-ground crank which is all i need
the rest of the engine is absoloutly tip top and never skips a beat as its had a lot of time spent on it getting it running spot on (within reason because of the crank)
i have a spare ADX engine that i ran prior to the conversion which is a 1.3 but i dont really wanna waste time stripping it back to find its completely wrong
so if you or anyone has any sugestions it would be getting me out of a big mess before a shell spins over or something £££ related
polo gt
obviously eitther read it wrong ? :dontknow:
Re: polo gt
shinny said
i heard that you had to do something to the top of the pistons to compensate for the gt camshaft??
Nope :wink: I ran an ABD with a GT cam and none of that was needed. Absolutely no more hassle than fitting any of the polo engines
GT engines are an absolute rip off as well, and ABDs are very cheap and much faster when coupled with the GT cam 8)
polo gt
polo gt
The ABD head may or may not have the double valve springs but it won't make a difference either way, the only thing which makes a noticeable difference between the GT, ABD, and the rest of the polo 1.3 engines is the cam.
Fit ABD, fit GT cam, fit bike carbs or whatever, and you'll have a car which embarasses 1.8s 8)
polo gt
i am thinking of fitting the whole abd engine as it gives me a chance to work on it when its out the car and still have my daily
GT gearbox also?..my one is excellent although constant gear changing is wearing a bit thin
as for throttle bodies/ twin carbs…i havent seen anything on it for a gt and the idea of it having to go on a rolling road to get the most is putting me off the mose…i would prefer tbs and keep the fuel rail as aposed to carb 8) any help on that??
struggling to find an engine close enough though and at a right price also
