Please help - Weber 32/34 carb on 1.8 clipper
(In Topic #134818)
A golf specialist garage is fitting it today but just had a call to say, the weber carb is on the engine fine, but the K&N air filter i bought to go on it fits perfectly on the weber but it wont fit under the bulkhead on the car. (not sure if bulkhead is the right word, the metal bit with the scuttle tray in it. He said the filter sits too high and wont fit under.
What can i do?
He is botching the old air filter on it so i can run it home atleast. Do i need a different air filter? different fitting?
So confused
PLEASE HELP GUYS.
P.S: this is the air filter: K&N 56-9025 Custom Racing Assembly single
Thanks a lot
I have been there and bought this particular T shirt, it will also run badly when the weather gets colder if you run the K&N, fit an insert (BBT do them) and you will be happy as a sand boy!
The fleet stands at:
'90 Clipper
'95 T4 lwb
'94 T4 lwb
'90 Clipper
'95 T4 lwb
'94 T4 lwb
The carb is amazing, such a difference, although it some trouble starting up quite badly and the emissions are sky high on it at the moment, its second hand so im hoping it just needs bedding in properly. been off a car for quite a while.
When you say adaptor plate, do you mean between the carb and air box housing?? On mine it was just a plate that screwed on to top of carb?? is this part of the Webber kit, sounds like you might be missing a bit??
'90 Clipper
'95 T4 lwb
'94 T4 lwb
'90 Clipper
'95 T4 lwb
'94 T4 lwb
And yes it's a plate that will sit between the carb and the air box, definatly missing this so need to find one to buy, harder than I thought to find though.
You will need the S bracket which connects to the carb via a small stud screwed into the carb and secure with a 10mm nut, along with that you need the hex headed small bolt and washer which will go through the hole on the original airbox, if you've not noticed your box will have a rubber bung, simply remove this and the bolt and washer go there and screw onto the S bracket fitted on the cab
AlsoMay i suggest you stay clear of those air filter units you just brought as in the older days, winter months you will suffer carb icing as no warm air feed going to the carb.
on the 1.6, 1.8 blocks replacing with a weber is excellent choice, but in order for one to fit it needs an adaptor plate which sits between the bottom of carb and the black rubber carb flange thus the weber sits higher and you can nt fit the airbox you brought.
Simply as i do use existing airbox and buy a performance air filter for that box, i have 2 new here, spares for the future, one is a brand new in box K&N air filter, exactly what i use on both my mk1 & mk2's, use for approx 5 month and i clean them out and re-oil.
Also when weber fitted you can not fit standard top mount strut brace due to the height rise of carb as it would put alot of pressure on the carb flange thus causing it to break, split etc and cause air leaks and bad running.
Whereas with pierburg original carb you can fit brace.
Fit original airbox, get performance air filter for the original box and you can then enjoy the carb more.
Not being funny but the word 'specialist' is being used too much, a golf specialist? i doubt it, as clearly he should have told you the airbox wouldn't have fited if you fitting a weber carb
Pete
The original air box is already on the carb all linked up, but its just not got the proper adapter plater to fit it on, so it just tied down (temporary fix) I have sent out some emails to webcom and other places asking if the can supply me an adapter plate.
Booking the car into another garage to get them to tune it for me, so fingers crossed. Would love to attempt to tune it myself but dont know anywhere near enough yet lol
Thanks again! i will keep you posted.
Can anyone give me a link to the right air filter that i need?
I bought this one on ebay quite cheap - http://www.knfilters.com/search/product.aspx?Prod=33-2002
and its twice the size of my original one, do you think i need this one instead: http://www.knfilters.com/search/product.aspx?Prod=33-2092
im not too sure…
Thanks chaps.
Starting to become a pain in bum now
Any suggestions?
Couple of thoughts though…
1: Do you have any fuel/rust issues?
2: Was the Weber new, or used? If used, could be a needle valve issue/
3: Return fuel line… On the 'rocco,(1.8 EX engine) I found I had to restrict the return line (down to 1.5mm)
4: Vacuum issue? You only actually need a pipe from the dizzy to the weber for it to function. You'd need to T off to the air flap in the airbox, but that's all.
Also noticed on some of the other photos from other forum posts that i dont have a 'T-piece'? well i cant find one anyway.
Also in the 4th pic down, (this baffled me the other day) the two pipes coming off the bigger one that goes fromt he bulk head to slave cyclinder for the brakes (ithink) one has a round cap on, and the other is just contantly sucking in air, but if you cover the pipe up the engine increases revving and actually runs better. CONFUSED.COM
my brain hurts.
Right, can i ask, have you looked at my pipe diagram, i take it you haven't as this is why air is sucking in, you have no t-piece as you have to buy one lol.
The bracket on the front with new weber you get two extended hex type length adaptors that screw onto the 2 middle rocker cover studs. these you should be able to get from a dealer.
Reason you need these is the weber as an adaptor plate underneath thet the carb bolts too and that plate bolts to teh carb flange on teh inlet manifold which in turn raises the height of the carb, thus once a weber fitted you can not use a top strut brace as no one as made for them a weber conversion.
You over come it by simply making an extension yourself.
Also may i ask what is the gold colour metal under the bolt and washer on the top of air box as it is not needed and i have never seen one comes with a weber.
Don't forget make an earth from carb to rocker.
Here is how to for your vac pipe setup and also your original pics resized
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=50160
Pete :wink:
so…i started the car and for about 3 mins it ran amazing, perfect running, then it just went back to its old tricks again, after it warmed up it just started hunting for idle again, it still runs but its not smooth, the exhaust sounds like its puffing out loudly, not smooth at all. Wonder if there is a deeper underlying problem somewhere.
quick question though (pics attached - correctly this time i hope )
The pipe with the red arrows was connected to a pin on the air box, you can see this in the 3rd photo above in the last post, but this is where the next piping is now attached, so i didnt know where it supposed to go. The green labled pipe in the 2nd photo looked just like a breather pipe, so for now i just connected the 2 together which didnt really make a difference, but i dont know where its supposed to go. any ideas?
