1.8 8v turbo technics HELLLLLLLP please
But looks like a MK2 rocker cover, mk2 inlet manifold, mk2 overun valve, Mk2 Throttle body (you can see the top where the throttle cable goes is more like a audi / 16v housing. so is that a G60 lump with the TT Parts added ?
DMArk - might be a good option to you if you dont mind loosing the originality and as MK!Turbo says Old skool tuning, unfortunately mines too original to warrant going this route, but i'm sure i would do if i had the chance.
PS: Mine can be driven how it should be if i wanted to - but i;m too old now to drive it like that - that's what my new cars for
Mk1 Lahsa green, BBS RM, Mk1 Silver Campaign, Mk5 GT TDi, Audi A4 Avant S Line
Exactly MK1Turbo.mk1turbo said
each to there own.
My AA membership will get me home (although its hasnt gone bang for 100,000 miles on k-jet yet )
Mind you if the tt metering head is worth that much i could always sell that lol.
In your position i can understand going down that route, but nowadays it would be heartbreaking to see someone dismantle a genuine tt kitted mk1 just to try and get more hp.
Get it running right and enjoy the fact that you have a very rare little beast.
Many 20vt etc not as many G60 turboed Mk1 but very very few Turbo Technics Mk1s.
I think Turbtechnicsmk1 is the only original one that has come out of this conversation. Mine is running a mk2 inlet so thats not original.
Can understand your route Alan if the kit is that hard to get, i'm fortunate to have owned it for a long time so know its all correct.
I (and i believe MK1turbo) know Interpro - we had a rolling road shoot out with them when GolfExtreme was around (there's that age thing again!!), but the guys that looked after us weren't too upto speed on the TT back then.
Another option for fueling has always been a Saab turbo metering head or the volvo ones, as they were CIS and could sense boost - finding one of those might be an idea for DMArk.
DMArk - looks like we've gone off topic and highjacked his thread - we should bear this in mind. Perhaps start a new thread to do the Old V's new methods ? Be a shame to not keep chatting this stuff thru :wink:, but lets try and help DMark in his quest to get his car running, so sure he will appreciate any ideas, perhaps cheaper ones ? as the poor chap has alreasdy started sticking his hand in his pocket :cry:
So dmark where have you got to today?
Did start looking at G60 piston sizes. You might be just as well getting a G60 bottom end to lower the comp as they seem to be pretty cheap.
Slight deviation but if any one has the info for these engines can they put it on the other thread I started ?
It would be great to get an idea of Power, torque, boost, timing etc etc to use as a base line when setting up these rare beasts.
:twisted:
had a buthchers at the pistons they appear to have been machined as they have no raised half moon shaped bit at the back of the crown
set ign timing to 28 deg btdc w/o vac, set fuelling to around 4% co at idle when warm
i replaced the boost t for a straight pipe from turbo to actuator and it wouldn't boost at all so swapped them back over and it now works perfect, presuming the springs in the new actuator are too weak, boost is at 13 psi with no det or pinking or any real noticeable problems to be fair the only problem i now have is with it being a carb fuel tank, when you put the car under load or go round a bend sharply it coughs as if no fuel , but in a straight line it's just perfect well quite awesome really also swapped the metering head bellows for a standard one this also appears to have helped.
the only thing that worrys me is if it is detting at top end and i can't hear it, all original problems have gone tho!!
other things on my mind are the clutch, which best suits my application, and what grade oil ie something around 10w40 or thicker??
oooh forgot to mention new injectors are now in and i've re-connected the little valve in the vac advance line.
have also checked part numbers on the metering head and they cross refer to it being a 1600 metering head, the plunger in the bottom of the metering head is quite a bit larger in daimeter than a std 1800 gti one tho.
with regards to the metering head there is a porsche 924 turbo one on e bay would this be ok for my lump or would it over fuel as i think the 924 turbo is a 2.5 as opposed to a 1.8
p.s. loving the hijacked post tho and the pics guys
cylinder head is cracked between vales :? not sure if this is gonna be a problem tho coz i've seen this a lot on deisels and it's never been a problem. now the inlet valves appear to be bigger (40mm diameter)
bore size is 81mm, the dish in the top of the pisons are 4mm deep as is the drop from the piston crown to the top of the block
pics to follow
quuick reply before i fly out the door.
Pictons - yep they look right. Bowls cenatrlised and lip removed.
Cracking between valves, common on GTI lumps - had this on a 1.6GTI head. reckon its because they leave so little space between valves. Never created any problems for me in the past on other engines. If its not causing any issues i wouldn;t worry about it.
as for the solid/hydraulic lifter thing yesterday i think i was having a blonde moment :redfaced: .
progress report and some pics to follow.
