safe fuel pump connection - S1 loom and CE2 fusebox
you could use later mk1/cabby/rocco CE1 car loom, or go 1 better and splice in ce2 fusebox. its more work though! no need to really though, the CE1 fusebox is fine.
the k-jet relay i mention on the last page will work fine with carbs, just as long as you have a mk1 compatible rev counter signal, which you should if using kr managment.
you can also use a later mk2 digi/16v or mk3 67/80/167 fuel pump relay or even a std switched relay with the kr loom. run the red/yel wire from the ecu 2 pin plug and use it as the relay earth, and the ign live input and output wires as per std switched live relay
relay pin ————————– connection
30 ————————— Terminal 30/H on the fusebox
31 ————————— the earth spider above the fusebox
15 —————————- pin 15 on the ignition switch
87 —————————– to the red/yellow +12v to pump
31b —————————— to the coil pin 1
Lee-dub - i am following you down the s1 route with ce1 board - just a different engine… hope to see you at a meet in near future.
Rubjonny - definitely have a few beer tokens for you and Lee in my pocket……..
1980 Series 1 GTI (gone now .. what a mistake selling her!)
1979 Series 1 LD - the Mandarin Dragon … gone as well. oh dear.
Its easy once you click how it works, look at the haynes wiring diagram…
