safe fuel pump connection - S1 loom and CE2 fusebox
(In Topic #134124)
I need to connect the fuel pump. i am going down the carb route so that does away with a lot of gubbins. The wiring that came with the car is butchered hence i am trying to sort what is there and what is not (and why)…. this is where i need your help.
the live to the pump is currently connected into the rear loom, it is the standard red/yellow but does not run into the D connector on the fusebox but rather ends like this….. into a slicer with a spare connector and one with a short red wire with a female spade.
attached to the same loom is the following relay…
and a s1 connector…
The other thing is that the D15 connector wire is burnt out that usually connects to the coil (15) and instead there is a spare wire in the loom which is black, 1.5mm and ends in a female spade at each end. My theory is that the black cable connects to the coil (15) and this connects to the spare connection onto the pump (1st picture). This would provide a live feed to the pump from the coil.
Would really appreciate some advice or direction if anybody has any thoughts. I do not want a permanent live to the pump for obvious safety reasons…..
Cheers.
1980 Series 1 GTI (gone now .. what a mistake selling her!)
1979 Series 1 LD - the Mandarin Dragon … gone as well. oh dear.
The relay needs a switched ignition 12 volt and the neg from the coil ( This so the pump only running when the dizzy outputs a ground), plus a constant ground.
then you have a battery 12volt in then the output to the pump ( This is the red/ yellow).
Pin 15 switched ignition
Pin 31 ground
Pin 31b coil neg
Pin 30 battery 12volt
Pin 87 output to fuel pump via 15amp fuse.
These are the pin numbers found on the fuel pump socket in fusebox
Clear as mud?
1981 Cabby 1.6 GLi
2006 A4 S line avant
as above you should havea permanant live from the fusebox to the relay. This goes to pin 30! this voltage is switched to the red/yellow wire when the relay is operated by the switched ignition or the coil negative wires….
Pin 31 ground
Pin 31b coil neg
Are they on the relay itself or the relay plate? Neither of which match up.. the relay i have is shown below
and the pins on the base of the relay read 53 - 31 - 15 - L (clockwise from the top)
sorry for the crap photo but you get the picture…… Am I looking at the wrong relay? or is this an incorrect fuel pump relay for this application and hence needs to be changed?
That is a fuel pump relay mate! note the pin numbers
Time for me to buy a relay and relay plate and get this bad boy wired up! Do you know how/where the best place would be to source these parts - and is there a list of different relay and their associated uses just so I do not make this mistake again?
Thanks again for the help mate. Its appreciated.
Website Manager
Someone has bypassed this and fitted a standard relay that just needs a positive to operate, probably from the ignition circuit (15) on the wiring diagrams. Later Golfs used a similar relay with the ECU controlling the fuel cutoff should the engine stop.
If you were in a crash and the engine stopped then the pump would continue to pump fuel - not good. You really do need to consider adding a correct fuel pump relay back in to the fuse box and put the wiring right.
Have you got a Haynes manual ? The connector letters, pin numbers and wire colours are laid out very clearly, if you need help using them, then just shout !!
I very definitely did want a safety cut-off on the pump!!! Cheers.
relay pin ————————– connection
30 ————————— Terminal 30/H on the fusebox
31 ————————— the earth spider above the fusebox
15 —————————- pin 15 on the ignition switch
87 —————————– to the red/yellow +12v to pump
31b —————————— to the coil pin 1
Do that and it will pump correctly when it should :-)
Oh and the relay is available from GSF £19.something I have no idea for the plate - actually I need one of these….
Off a previous post by the famous rubjonny…
the correct relay is 321 906 059G, or you can buy this one from GSF:
935VG0090 - k-jet relay - £ 23.20
do you know which would be suitable for a KR engine on carbs with KR ECU? Did you get the relay plate at the same place as the relay itself? GSF?
Thanks again mate for your help.
no pin 15 on the ignition switch is the connector at the back of where you put your key in. If you follow that back to the fusebox and tap into that…. Its on the fusebox guide on here what pin it goes to at the fusebox, just take a feed off that wire
Hope your gasket issue is sorted soon!
dilemma's dilemma's …..
