16v kr conversion wiring loom
then when you are happy you can wrap it up in your desired tape or harness wrap, i recommend this stuff which is pretty much identical to the OEM VW harness tape:
http://cgi.ebay.co.uk/Scapa-Rayon-Cloth-Wiring-Loom-Tape-1-Rolls-18mm-x-25m-/270533414190
it will be a quality job, but then i suppose im biased. if it helps I think I have wiring OCD, for one thing i removed my entire dash so i could replace the spliced stereo loom for a completely uncut loom i spent nearly 2 hours removing from a MK3 golf in the scrappy, including the proper key-in-ignition live feed from the ign switch. i also put in the lights on warnign buzzer while i was there. all without cutting any wires
ive done loads of looms for peeps on many forums so hopefully someone can vouch for my work
Will it come back ready to plug in to my fusebox?
The brown connector that fits onto the temperatue sensor on the side of my cylinder head needs some attention as the wires have broken off, I have the connector, would you sort that out too?
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=38676
and another one i wrote:
http://www.clubgti.co.uk/forum/showthread.php?t=173722
by the sounds of it once you get your head round this you should have no problem doing the job, KR wiring conversion is pretty much the simplest one you can start with
What was the loom you mentioned that goes behind the dash for the isv? I think that bits missing. The 3 connectors I have from the isv look as though they would have plugged into the corrado fuse box.
I have looked at the wiring diagrams too, and I have to say suprisingly they're starting to become clearer and make more sense.
But, I'm not certain on where to connect the 3 wires coming from the ecu loom, so I'm just wondering if you can confirm my thinking is right.
Black/ yellow stays connected and goes to the throttle valve switch.
Black/ White I connect to the coil +ve.
And red/ yellow I'm unsure of because it says connect to D13, but the D13 on my original fuse box is empty :dontknow:
Black/White - ecu pin 5, ign live feed from coil +ve
red/yellow - fuel pump trigger to D/13
with the last one this is needed if you want to use a proper 16v/EFI type fuel pump relay. rather than a rev counter signal these use a -ve trigger from the ECU.
Since your car was a carby there is no fuel pump wiring either, so you will also need to add a pin to E/14 for the fuel pump, plus a thinner wire on a spade connector for the WUR. See the last diagram for this, the 1 pin connector is T1g on there. its just a spade connector hanging off E/14 on a short length of wire, this means the engine loom can be split from the car. if it was joined to E/14 then you wouldn't be able to disconnect it without cutting the wire if you know what I mean?
You have 2 choices to go with this:
1. find a random spare CE1 fusebox loom and chop out pins from it for D/13 and E/14 (E/14 is the larger pin type fyi) then pop these into your fusebox plugs.
2. wire up a separate relay above the fusebox, if you do this use a std automotive switched 40a relay. Wire this up as usual except run the earth for it to the red/yel wire, rather than direct to ground.
you could use a k-jet relay without a rev limiter in the fusebox, that way you can leave the red/yel wire to D/13 disconnected but you would still need to add an E/14 pin.
Oh and don't forget to add the fuel pump fuse 5 if you add all the fuel pump wiring to the fusebox
So can I connect the black/white wire from the ecu direct to the coil +ve?
I'll have to have a think about the red/yellow wire and study the diagram and your instructions cause it sounds complicated.
If I can just concentrate on the coil wiring for now i'll conquer the rest one step at a time.
So, to coil -ve Should I connect the green from ecu loom direct to it, The red/black from the isv which splits from the spade connector, and the red/black from d16 on my original fuse box.
+ve side of coil, Black from ecu loom, black/white from the 3 pin female connector (which shares the same connector as the red/yellow and black, yellow) and the wiring diagram shows a black wire coming from d23 on my original fuse box that goes to the coil aswell, which I presume connects to the +ve connector too.
you should be able to figure it out with a bit of reading, simply put the ECU controls the fuel pump on th 16v and later VWs, using an earth trigger wire. the relay itself is just a switched relay with no complicated gubbins inside, so it has an ign live, a live and an output to the pump. instead of the earth being direct to ground,it runs to the ecu via D/13. early k-jet cars instead have a relay which takes a rev counter input, this is why if you pop one of these in you can ignore the D/13 wire.
coil -ve yes, you run the green wire from the tci to here. this is what tells the coil to spark.
then you have the red/black wire to the fusebox, this is the signal for your rev counter. last of all on the 16v there is an extra wire with a spade, this is the rev counter signal to the isv control box, so it knows what the revs are
D/23 is the live feed from the ignition switch which powers the coil, the wires from the tci and ecu are piggybacking to this feed so they also get power from the ignition switch. you could run these to a separate ign live feed if you wanted, its just vw chose to run them off the coil +ve side.
on the coil all the pins on the + side are joined together, same with the 2 pins on the -ve side.
the coil gets power from the fusebox, and the tci/ecu piggy back off this feed. the coil is triggered to fire by the -ve feed to the TCI unit, the rev counter/isv piggy bag off this signal so they 'see' when the coil has fired
edit: oh, its worth noting the massive spade terminal 'N' is also a fuel pump feed, so you could run the pump and WUR to this. it is not fused however so you'll need to put an inline fuse in the feed wire. this is up to you, I prefer to wire everything as per factory, but there is no reason why you cant do it this way. the advantage is if you use this and a k-jet relay from gsf without a limiter, you wont need to add the D13 and E/14 fusebox pins
I bagged myself a lift pump and reservoir, and an early 16v airbox at the weekend too. Hopefully, just got the fuel lines, drive shafts and an exhast to sort when my wiring is done and she should be almost there. Oh, and the gear linkage problem.
I can't select 4th or 5th and 3rd is a struggle to find. I had to convert my gearlinkage to gti spec too as the 1.3 linkage was different. I replaced all the bushes, it probably needs adjusting.
This wiring loom goes from one extreme to the other, I thought it was going suprisingly until I discovered my new dilemma.
The black/White wire from the ecu that I thought would connect straight onto the coil +ve is more difficult than I thought. It's only black/ White from the ecu and upto the connector. After the connector it's just black and then the black wire splits into 2 black wires. 1 black wire goes to the over run valve, the other black wire goes to an old corrado fuse box plug, but the connector in the plug is crimmped to has another black wire crimmped to the same connector which connects the isv. Then it's the same story again in the isv, it also has 2 wires connected together and another black wire that goes to the throttle switch.
So basically, the black wire goes from the origional black/White ecu wire, turns black after the connector, splits one to the over run, the other to the throttle valve switch via an old fuse box plug and the isv.
Also, the isv has 2 wires that I need to do something with, a green wire about 3 inches long and has a spade connector on it, and a blue/ black wire also with a spade connector on. My guess is the blue/ black wire would connect to one of the 3 spades on the side of the cyl head for water temp, but I don't need it now because the original mk1 wire replaces it, but I'm lost on the green one.
Please help !!
car side of this chop out the bit that went to the coil,and run the over-run valve to an ign live from the fusebox as per the diagram I sent you
OR retain the 3 pin corrado plug, and splice the fusebox black wire you have to the over-run valve ign live feed as per the diagram I sent you. either way will work!
as above, green wire isnt required, but the blue/black is probably the isv control unit ign live feed. again, double check the diagram i sent you and run it to the fusebox where it tells you
at the end of the day remember that the golf and corrado 16v controls are the same, its only the wiring location and routing that differs here and there. the golf wiring diagram will tell you exactly how it needs to be wired to your fusebox
just take the DX out, bolt in the kr the same way. the bits you need to change are the manifold & downpipe, plus the engine bay bits of the fuel system and electrical stuff.
physically it will bolt in the same way using all the old mounts and running gear, the odl fuel pump will be fine, though the fuel lines will need bending over to the driver side, or replace the lot with crazyquiffs mk1 16v fuel line kit. before you bend the old lines inspect them carefully, if they're starting to rot then bin em!
