From faulty alternator to full rebuild! (now with pics)
(In Topic #133305)
But upon removing the head (only ever worked on 1.3 engine before) it transpired piston number 2 was sitting 3/4mm lower than number 3. Uh-oh, bent conrod or bust big end bearing. The engine had run fine but on 200K ish was always a little noisy. Probably added to by the fact an exhaust manifold stud was missing.
So now I embark on a full rebuild. Went to get a replacement engine today (thanks Hibbs) and took it apart tonight to find the headgasket stuck on with sealant but….the block is in good shape, hooray!
So tomorrow I will take more parts off the bottom end, give it all a good clean and paint some parts up. The engine bay has a had a quick clean but I plan to do some more once the old bottom end is out. Going to build the whole thing up before it goes back in. My first close up experience with a non Polo engine, it's good to be learning my way around it more.
Will post some pictures tomorrow but here is my golf a few weeks ago:
And Slovenia last year before the new roof:
Oh well will get there somehow.
Today I took apart my engine after my friend helped me take it out last week. Super easy the second time around when you know the tricks to get stuff undone. My parents are still talking to me despite the state of the garage as well, bonus.
Cleaned inlet mani vs non cleaned, now all built up I'm happy to say.
To get the inner flywheel bolts off, helped by metal toolbox stopping the engine turning!
Sump off, looks weird eh?
To hold engine still, whilst undoing crackshaft nut…I need help later as engine keeps lifting.
Dirty face (pressure washed gearbox) but clean hands thanks to gloves
And the bay after cleaning.
Whole bottom end should be apart tonight. Got bottom end gaskets on the way, ordering piston rings tomorrow and getting my honing tool on Wednesday. Just need a clutch now! Anyone know where I can get a Sachs one cheapish?
Got a local garage to undo the pesky crankshaft nut in exchange for some biscuits.
Started taking some bits out of the bottom end but needed to walk my dog so left it for tonight.
Finishing it tomorrow and ordering all the part on Friday so can start rebuilding after cleaning and painting everything at the weekend.
Engine's are fun. Think whole rebuild will come in at under £500, not the best when you earn national minimum but I'll get there…just need to find a cheap alternator and clutch.
You say you were standing on the hard shoulder and someone hit your car at 70+mph which then ran you over?!?!? That is soooo not right!
BTW - cracking idea with the spanners to undo the crank shaft nut!
My Build Thread
Spanners idea wasn't mine, I found it on here but there was no pic. So thought I would post one to help people! It took a big ass bar on it in the end though.
Back working on it tonight, just got back from a 10 hour day working with kids and no break haha.
Whats the latest on the engine rebuild ?
Tues and Weds night I got the rest of the bottom end apart:
So initial diagnosis of 2 bent conrods was correct, check these 2 wonky friends out:
Sorry about the Beirut garage mum…
So now I go to clean the internals I am using, needing this:
And a little bath for piston and conrod:
Before with after:
All done:
Coated in clean oil and wrapped back up:
Got my piston rings and big end bearings ordered today and started cleaning the block ready to be painted.
Clutch and alternator not til next month at least, unless GSF come good and refund me some money.
When you want the handles too?
Keep up the good work on the engine.
Could you not have lifted the one out the blue cabby lol?
Chortle
Before
After (new bolts from VW)
And here's the engine up to the other night (done more since, now got sump, new core plugs, and crankshaft fitted)
What are these? Flippin expensive!
Voilą…
Add to piston…
And then take a cleaned, painted, bare block…
And in they go…
Roll on Romania!
Here's another update for the millions of people that have replied. ;-)
Gearbox before
And ready to go on…
Core plugs fitted
Rocker finished
Starter finished
Engine this morning
Now fitted the gearbox too.
Can't believe it went to Croatia and back like that!
I know neither can I, good on it though!
Gearbox is now on, next step is to fit new engine mounts, back of cam belt cover, and the final pulley. Then it's head (after some work) exhaust and inlet manifold and should be good to go. Then just 500 miles to run in, and got to be before I take it to Romania on July 23rd.
Thanks for the reply.
I may well come down on the Friday night, I'm not a paid member though so don't think I'm allowed in! I will be at some point (i.e. When my clipper Gti is sold!).
Would be good to meet some new people, then they might reply to my thread hahaha.
Derby and Leics crew should all meet up before then, any excuse to run it in with some miles. :-)
