New Clutch
(In Topic #131774)
New Clutch
Im about to buy this clutch from gsf for my turbo conversion can anyone confirm that its the right one? Im using the 027 105 273 flywheel which is 210mm
189VG0700 CLUTCH KIT-210mm G1 1.8 F.Inj 8/82 >12/83 50.50
Cheers in advance
1.3 Driver - 1.8t in progress
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=56551
Daily driver : e36 325 tdi se / slammed on konis and bbs rco401's
Daily offroader : discovery 1 6" lift monster
What box are you using mate?
Cheers again
Cheers anyway man!
just buy it and then remove the plate and offer it up to the input spline to the box (inside bell housing) if it fits then bobs you uncle
jj weir
jj weir
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
What you running now mate? Howd you find it?
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
I was running it on a cable conversion but is really heavy and before that I had a floor mounted pedal box that was truly rubbish.
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
BMW R1200GSA
Caddy 2k 1.8T
jj weir
Put some of my mr2 spares on ebay to make some space! Been hot right till i come in from work then gets cold like! :wink:
What about yer self?
the gearbox decides which clutch you need, either 8v or 16v as the 8v uses a smaller spline than the mk2 16v boxes. sicne 16v clutches only come in 210mm you need to change the flywheel if its a 190 or 200mm one
