Where is the noise coming from????
Removed one wire from the feed to the fuel pump to test the lift pump in tank, turned the key one click and I could hear the lift pump "prime". I then reconnected the fuel pump wire and connected a pipe to the outlet pipe on the lift pump and turned the key one click again and a healthy squirt of fuel came out in to my bucket. To be sure, I removed the lift pump to check the filter and it was clean and looked like new. The car now runs without the fuel pump buzzing but you can hear it working if you lie down and put your ear next to it, the only thing is the car idles a little high once warmed up????
what it could be was the reservoir under the car was not filling up for some reason, now you've messed about priming a load of times the reservoir is now full up?
might be worth a check to make sure the reservoir is actually there, its a while plastic box with 4 pipe connections on it
