Where is the noise coming from????
(In Topic #129554)
1979 S1 MK1 Golf L FOR SALE! http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=101471
1970 VW Beetle 1600 Twin 34 ICT\'s - Betty
1973 Marathon Beetle - The Moll\'s
Do you have the foam insert in as this reduces the buzzing slightly?
check your in-tank lift pump. this keeps the main pump supplied with fuel and if it packs in the main pump has to strain hence the very loud buzzing. disconnect one of the wires to the main pump then turn key 1 click, should hear the in-tank pump prime. unless yours doesnt prime on the key, otherwise you'll have to crank it over. be harder to hear the lift pump tho!
its under the rear seat and accessible once you remove the black metal plate
Cheers for your help guys
just a case of finding something which will get you the leverage you need, as you say heat there wouldnt be a good plan!
drop pump back in tank, point this pipe into a bucket and tuern key 1 click, the lifter pump should spray out a nice jet of fuel
