Connecting my choke? Weber conversion URGENT HELP REQUIRED!
EDIT-Hey folks, have a weber conversion, have the manual choke cable there, just not attached to anything, Where does the cable run in the engine bay after it comes out of the dash, also which part does it connect to on the right hand side of the carb.
UPDATE- The choke mechanism is cable-tied open, so providing you lot tell me everything is there, and where to route the choke cable. I can start having some fun!
I just need to know HOW I connect the cable to the choke lever, and where to route the cable/how long the cable needs to be?
Currently, i'm having to replicate the choke by blocking part of the top of the carb to richen the mixture, not fun trying to start it!
Cheers,
Alex
1979 S1 MK1 Golf L FOR SALE! http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=101471
1970 VW Beetle 1600 Twin 34 ICT\'s - Betty
1973 Marathon Beetle - The Moll\'s
I can get better pictures?
Alex
Anyone?
Help :(
ttt
if the choke cable isn't attached this is the problem
have you any better photos and we might be able to help
Sure thing :) I'll get some tomorrow,
I have a choke cable, just not connected to anything!
Ta
Alex
Any idea's?
Pics coming in a mo
Updated first post ^
HUP for the evening lot!
HUP!
Hi Alex
The choke cable on mine loops round over the top of the engineand pulls from the front,the outer cable is clamped onto a bracket (battery side of the carb) your bracket looks to be at the rear? Not sure thats the same as the weber on my car,recently had to swap mine due to a leaking diaphragm, tried to post some pictures for you but cant as photobucket seems to be down for maintenance,will get some up asap. Pete
Brilliant explanation, much appreciated :)
pics would be great whenever photobucket stop being stupid!
Ta
Alex
http://i1006.photobucket.com/albums/af181/woodpm/033.jpg
Hi Alex,hope this helps you, weber carb off my 1.8 cabby.
Left side of the picture is pointing at the front of the car,viewed from the passenger side if that makes any sense?
Bracket on the left is where the choke outer cable clamps to, inner cable goes into the clamping bolt in the centre of the picture. Pete
Brilliant, that helps a lot!
Will give it a go in my lunch break tomorrow, and report back!
Cheers,
Alex
That carb is different which is a 32/34dtml for 1.6 & 1.8 and, the 1.5 36tlp is slighty different.
I have pics somewhere of when i fitted my friends.
If not i will call him for some piccies for you fella.
But to me it looks like something missing from right side of the carb.
Will find those pics
Pete
Brilliant,
Much appreciated pete!
Worst fear is it's missing some important linkage :( Can't really afford to fork out for another carb
Alex
Just spoke to mate his golf is at his mothers house i will get her to take a pic when she home from work bud, hopefully get pic up for you this evening
Brilliant, can't say a big enough thank you!
Cheers,
Alex
Just done some more research, found this:
Isn't looking too good with the carb being complete :(
