mk1 1.3gt conversion - Help
I have decided to keep the motor as it is and get it running first, I will do the bike carb conversion at a later stage.
basically i have ditched the accumulator and just ran the pump and large filter
so it goes:
tank > lift pump > main pump > large filter > fuel rail
and return goes straight into the tank
i still need to add a filter before the main pump because I've heard the get clogged up easily
heres a diagram:
view from inside the car:
some rough pictures was hard to get a good shot!
hope this helps
as for the ecu loom, the red and brown near the afm go to the battery, the relays are for the fuel pump (red and yellow cable is live for both fuel pumps)
i'm not sure about the rest, if you post up some colours of wires i can compare with mine,
luckily mine had been labeled when it was removed from the polo
you do realize that when you go to bike carbs your not going to need any of the ecu?
as i said before i think the injection system is better than carbs tho
So would the entire ECU and loom be disregarded if going for bike carbs?
also you wont need the high pressure fuel pump
but the extra work to run the injection system will pay off i reckon as your motor will be more reliable, better fuel consumption etc
im not sure about the powetr difference between bike carbs and injection
Or do I still need it for the ignition?
Any info on that will be appreciated.
What doesn't kill me can only make me stronger.
Mk1 will be back.
Mk1 will be back.
then original mk1 loom for the other two pins on the starter motor solenoid
few more Q's if you dont mind helping. what fuel pump are you using? and do you have spare plugs left over from the GT loom?
i separated the ecu part of the loom and plumbed it into the mk1 golf loom, meaning the only redundant plug is the diagnostics plug.
3 pin - Black, black and red, brown wires near to throttle bodyarea
3 pin - red, black and red, yellow wires. with a slotted edge plug like its meant to slide into somewhere.
Any advice on where they go? cheers.
also on the other plug the middle wire of mine is not green it is black and red does that make a difference as its not being used?? what sould I do with the wires that are not being used, ie, yellow and white and green/red and black?
appreciate the help, got me going now to finish the thing!
i used small spade connecters to run a wire from the pins in the 3 pin polo connecters to the fusebox
this meant i just left the y/w wire as a pin in the plug, but if you have access to the correct parts from the polo loom your could wire in the diagnostics port
another question here, the 2 wires i am connecting to port 8s. did you thread them through the bulkhead and then splice just behind the fusebox or locate the wires elsewhere, oh and when you say splice do you just mean cut the old and join the new or actually keep the old and splice the new in aswell?
