project lead foot - resto underway!!
My Build Thread
mk1 golf - resto
mk3 polo breadie - daily banger
goin to attempt the rear arch inner tub half replacement soon. slightly daunting! dnt want it in the wrong place at all so i made a frame/jig that will allow the new tub to go back in line….i hope.
knocked this "masterpiece" uptonight, it comprises of two metal "pipes" that are the same diameter as the hole that the shocks goes through. i flared the ends so the they wont go all the way though the hole and the welded a bar/pipe accoss them.
made a frame for the floor that butts up against the rear panel on the off side an shaped it so it slots round the turret.
i then joined the frame and top half together with random right angle sheet steel. i addded two more pieces for more postion markers.
will it work, who knows….
looks strangley like grown up mechano…
mk1 golf - resto
today i hacked the rusty rear wheel arch tub out, it was a very sucky job to do. lots of rust flying everywhere an such. this is by far the rustiest part of the whole car and is a right pain in the arse which bit to do first!!!
i also put the car back on axle stands to for support asa large piece was gettin chopped out, i stood and sat in my car for the first time in a year today. floor pan took my weight so welds appear to be strong enough…..he hopes
where a tub used to live
inside the chassis legs. the rotted out too
this is the new tub i have to go in i got from fellow member millfishk69 who was cuttin up a shell. the front corner has had a repair to it previously and needs to be done again but the rest is solid and a million times better than what i had haha.
today i stripped the underseal off of it and removed the leftover bit of the other side of the tub by drilling out the spot welds. fricking 47 of em!!!!! blunted my drill bit too!!!
new arch, my cars guna be 1/16 lhasa green now…sweet.
more progress this week hopefully.
mk1 golf - resto
Mk1 Gti Cabby project on the go! Detailed engine, roof off, leather interior, 16's, painted, now getting put back together!
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=103263&start=0&postdays=0&postorder=asc
cheers guys, i wouldent recommend this job to anyone, it has really tested my patience these last few days, as all the surround bits were still attached to the new tub when i got it it feels like ive had to remove 2 tubs instead of one.
but after two days of cutting, trimming, grinding, drilling, swearing and more drilling i got it to slot into place nicely. wasnt really the sort of this u wana just hack into then make it fit afterwards.had to be right!
woop, woop!
i could start welding it in but i wana reapir that corner of the floor first and the rear axle chassis mounting point too. guna be an interestin shape to make!!
this is the hole i had to cut in the end, BARE GAPE
u can see the rotted other half and filler neck hole rotted lol.
mk1 golf - resto
got a few hours in this afternoon and did sumin i find quite enjoyable now, seems to be alot of fun compared to cuttin and pokin at rust. a solid piece of metal you say…..
after a wile measuring, contemplating then cuttin a template for this then spent maby an hour or two hammering i ended up with this rusclart.
this will live in this hole, decided to make this floor section in 2 or 3 sections. im not good enough with a hammer to make the hole panel in one! maby oneday….
more hammering tomoro
mk1 golf - resto
Where in the world are you (cronx I am not familiar with!)?
Hats off to you and best of luck!!
today was equally as testing as yesterday, my panel i made yesterday now fits nicely but the axle mount point repair panel on the other hand…..mmmm not so much. i mean way off.
i remember the other side was a pig to get on but now i have nothin to go against as its all rotten an cant hammer it and weld it like i did the other side as it was on my jig but on axle stands now!!!
guna take it to work tomoro an get sum seriouse heat on it an try reshape it abit better. i did drill, trim an prep it for welding though. only thing worth showin you lot today really lol.
mk1 golf - resto
its in, welded the tub in today. havent welded all the way round the floor as theres still sum rotten bits onit an theres no point trying to weld to rust if ur jus guna cut it out! def need a skim o filler on that top quater panel haha.
everything on my jig lines up ok
i also got this floor piece i made welded in. welded it to the top curve of the floor for now to keep the shape and such.
all welded and sprayed up for now. really contemplating buyin a whole boot floor. so many bits that would need to be patched and fabricated. would it be cheaper and less time consumin to get a whole floor?
mk1 golf - resto
mk1 golf - resto
Gi
today i repaired the front corner of the tub i jus put in, was a pain to make the shape and didnt want to fit for ages then it jus seemed to fall into place haha. result!
started with a cardbourd template an then onto a sheet,
lots of hammering later i ended up with this
i then cut this rotted bit out of the arch
then welded it in, not the tidiest weldin ive done but will suffice lol.
will finish it off with abit of grinding tomoro then set about gettin the other half of the tub in.
mk1 golf - resto
you can have my jig if you want as i dnt need it anymore. jus gota come get it is all.
mk1 golf - resto
It was the last one on his shelf although don't know if that means that they can't get more. Frustratingly I forgot to use my member discount! Doh!
Jig would be useful, was looking to make something, where would I have to get it from?
mk1 golf - resto
