shadydaz's First ever project...
Tidied up the back end a little ready for the new rear panel, but it won't be going on yet as still have a bit of rot to sort out..
Then tidyied up the wheel well hole ready for blank;
And removed the sludge form the swage lines in the last three panels;
Rear wing
Rear Wing
Door
Door
Some areas of the front slam panel were depressed inwards so had a bash;
Finally, I got the rear beam assembled, just the brake lines ot go!
Had to hoover the bloody rug afterwards of course! She went nuts!!!!!!!!
All bare metal zinc primed, going to start welding up the wee holes in the panels tomorrow night as is a relatively quiet job.
Thanks for looking.
Hairyarse said
Nice work on the beam. Rear panel if one of CQ's should fit like a glove
It is but there was a problem with it on arrival, trying to sort it out with them.
Was worried mine had been welded in out of place but it should be loose and was just held in the wrong place by the primer. A quick tap and it came loose.
Hope you get it sorted anyway
Hairyarse said
Its not the captive (but loose) plate that the boot catch bolts to is it?
No mate, will post some pics up later.
Ok, the delivery from CQ's was unfortunately wasn't packed properly so the enigne mounts scratched and dented as everthing rattled together in the box:
this is how the goods came out of the box;
But it is all getting sorted now so have no complaints, QC's are knidly collecting said parts and replacing FOC. Many Thanks to Richard
One engine mount and the front engine mount poly excaped intact!
Had lots of rivet holes in the front panel and swage lines so began the deleting process:
You can see that the panel hole has been butchered. I will endevour to straighten these cuts as best I can. Failing that, new front panel it is!
Also did a door and both rear panel, ready to grind back now and re-apply more to fill gaps on weekend hopefully!
Also, after reading Andy's (hairyarse's) thread earlier on I scared the life out of myself looking at some of his pics so had a bash at the underseal…
Looks ok at the momnet, there are a few little areas of concern but these by no means need cutting and patching, just get the rust eater on it after a good grind!
I should be able to keep going with the underneath in the evenings as not a very noisy job. Oh, and HD photos at last, if not a little shakey on the trigger!
Thanks for looking.
Daz.
