Project It'll be done when its done
All parts out side:
Me cleaning driveshafts, dont want any grit in those:
Engine ready to be put into its new home:
Geez doing the fitting:
Engine in place:
New pads & discs:
Servo & wrong master cylinder on:
What doesn't kill me can only make me stronger.
Mk1 will be back.
Mk1 will be back.
Rad fitted, plus right master cylinder and vaious hoses tidied up and finished off, new vacum hose made and fitted, egr system binned and blanked off.
The nearly infamous geezer's box'o'pipe - it dosent matter how many pipes you remove from it it never gets any smaller and will usually contain at least one of the pipes you desperatley need.
Not bad considering he's never broken a polo so these pipes are all mk2 golf or corrado stuff. Cooling system filled with g12+ mix and tested for leaks, none so far.
Correct late mk2 valver master cylinder, just need to collect some brake fittings and make a few pipes up. Brake circuits traced and run into tee's ready for connection.
Installing the looms, Geez cut out what we dont need from the old loom, wire's left in place ready to bridge over to the gt loom, should help to keep it a little neater.
ecu bracket made, painted and drying nicely.
Ecu bracket finished tonight and fitted up with the ecu, shown here fitted to Geez's mk1 as it was dark outside, raised section at rear is the mount for the ecu and fuel pump relays (seperate from main fuse box on gt polo looms ) and as from the pic will mount to heater motor shroud so i dont have to drill any hole in the leaky part of the scuttle area .
On call from tomorrow night and we are still waiting for the correct fuel hose to arrive so it maybe slow progress over the next week.
Mk1 will be back.
Mk1 will be back.
ecu tray transfered to my car .
Ecu and fuel pump relays fitted with velcro tape for easier removal should it be necessary.
Further on with the looms, Gt ones finished, some extensions required for the old loom.
Pretty much done, just cranking feed, fuel pump wires and the power to hook up. Also had to modifiy the temp gauge wiring as there'e nowhere for the old style sender to go, Geez soldered in a 90 spec temp sender plug, the gauge will be a little out but should still warn of impending doom.
All original loom and earthing finished with the head to coil pack.
All front brake pipes finished, there's a corroded rear pipe to change before it can be bled.
Mk1 will be back.
Mk1 will be back.
This is excellent cool to see you using the injection system too. Any issues with using the original tank?
I wish I had a box o'pipe
Polo lift pump fits straight in as a direct replacement. Dont ask about the electrics as thats not my thing.
Mk1 will be back.
Mk1 will be back.
2 bolts to secure throttlebody top hat.
Airbox was wedged in place….despite people saying it wont fit
Fuel pipes put in place
Then there was the moment of truth would my Schmidts fit with the new brakes….
JUST!!!
There were a couple of other bits like fit lift pump & wire it up but got no pics, and somethings I cant remember.
Went back up today and Geez had fitted the throttle cable & was sorting a bracket for the fuel pump & accumalator
Rear brake line changed
Lift pump wired
Bracket for the fuel pump & accumalator
And in place
Finally fuel filter from Polo 6n 16v I had spare fitted in engine bay, held in place with old coil bracket.
Geez done loads of little soldering jobs aswell and thats how it stands at the moment
Mk1 will be back.
Mk1 will be back.
Since the mot the exhaust has broke. On the positive side it means I can get rid of the coke can size supersprint for something more subtle.
Also still not got around to fitting the chip & afm but that'll be done soon as the exhaust sorted.
Mk1 will be back.
Mk1 will be back.
Mk1 will be back.
Mk1 will be back.
Mk1 will be back.
Mk1 will be back.
Mk1 will be back.
Mk1 will be back.
golf mk1 driver project
non sunroof
non sunroof
Mk1 will be back.
Mk1 will be back.
non sunroof
non sunroof
Cheers,
Jack
1983 Driver.
Quackers said
Fancy selling me that grill badge? aha
Cheers,
Jack
No sorry, it was difficult to find.
Mk1 will be back.
Mk1 will be back.
baller said
Really love this project ,nice to see a small block conversion done it makes it a bit special in my eyes and you have done such a great job.must be nice with a pepped up 1.3 and 5 speeder fitted. 20v turbos are great but this is a lovely up grade
Thanks mate, cant take credit for conversion as Geezer done most of it but I resisted the urge to go big block. Im hoping to AFH it soon(1.4 16v) as its the best small block out there with cheap tax & I miss my old 6n.
Mk1 will be back.
Mk1 will be back.
Mk1 will be back.
Mk1 will be back.
Mk1 will be back.
Mk1 will be back.
