failed MOT on emissions
Member of the month GET YOUR SAY IN NOW
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=86608&highlight=
This is due to the car not having a cat fitted as standard and the car is from south africa.
Even tho the car is registered as a 96 it is based on a mk1 golf and should be tested as such.
This seems to be a problem for alot of citi golf owners, as MOT testers test the car as a newer modern car when it is based on an older car.
you know you wan't a citi
chazsa said
What is needed for an emissions test on a mk1 citi golf 1,3 is to have the test done the same as an 83 mk1 1,5/1,6 and not have a cat test done on it.
A letter from the manufacturer, details on the previous link.
if you aint scrubbing......... you aint dubbing
ryanstratton said
mine failed on the same thing n my macanic striped the carb n cleaned it out put it back 2gethere n it then passed that might b all yours needs
Is yours a 1996 too?
Did they do a cat test, and if so how did it pass the lambda and CO without a cat?
