1.1 carb help
1.1 carb help
not going to make the agm though coz my #4 cylinder has a minor ring problem and i'm losing too much oil to do a cross country trip.
Unless another plan works out before then lol.
Oh and sorry to high jack the thread sedge!!!
should all 1.1's have the vac tanks for the inlet flap then as mine hasn't? if it's needed I'll have to get one!!!
Jon.
i don't think they do… I didn't have a vac tank on mine and mine hasn't been touched under the bonnet… Unless some have. I forgot to take the pics lol… Bummer..
booze and boredom, the greatest mix
Do you have an auto choke?
the pipe hes showing on the back of the carb is for the warm air feed, which he doesn't use as hes using an after market air filter.
all 1.1 engines with a solex carb had manual choke… infact i think all small blocks had manual choke..
might be wrong tho
just learned the bits form the bible i needed
I would normally bow to your greater expertise but that's not the case here. I can assure you my 1978 1.1cc has an auto choke - gave me a bit of grief at first until I set it just right now it works a treat…had to set the choke gap with a drill bit.
I'll show at the club meet if you're going.
thats a series 1 isnt it?
i would love to have a poke round i love old carbs… which is odd for a 22 year old… HAHA
what make carb is that on there then? its not the solex is it?
i have a vac hose going from the bottom to a disc on the side, i assumed you meant that thingy
You're right, it is a series 1
It's not odd to like this stuff. If it is I've been odd for years :wink:
It is the Solex carb yes. They get a lot of unfair press on here and I feel too many people want to swap out the carb maybe prematurely to correct running problems. I stuck with mine - tweaked it here and there, listened, then tweaked it again. It now runs like a dream.
My hose goes from the bottom of the carb round to a square block which sits against the disc. Inside the square block is a diaphragm which, as it moves in and out, operates the auto choke.
It takes a while to set it correctly and in cold, wet weather it may need a further tweak but touch wood (taps own head) it's been really good for a while.
only a few days left an we can compare carbs…. HAHAHA
i can see sedge has a manual choke as he has the choke cable on the right of the carb but now you have intrigued me lol.
well, looking forward to meeting you cleef look out for the ratty, half done, bumperless series 2… i hope ill be the only one thats in this bad of a state
im sure you will spot me
I'll be there on the Sunday in this:
