Stretch Tyres what PSI and 1 leaking
(In Topic #125324)
i have 40psi in all wheels fitted today and drove about 5miles before pulled over to check all ok and rear passenger left was down to 10psi and still hissing out air
its leaking between bead and rim they were all pumped to 70psi and left over night to help sit them properly. have pumped wheel up and at about 60psi no air leek but cant run them that high?
whats best way to stop leak?
and what is a good psi for them all to be at?
30psi is the best pressure by putting 70psi in your just going to ruin the tyre the reason its leaking is because its the wrong tyre for the wheel
sorry i cant be any more help other than telling you your tyres are going to fall off lol
Using narrower wheels with the tyre size, will firstly allow the wheel to sit within the bodywork of the car (so its not illegal) and secondly operate within the fitting size range of the tyre, making fitment easier and allowing the easy application of bead seal before its fitted.
It might be that those tyres are too wide anyway, so need to be slightly narrower.
So as a result, no matter what size of wheel/tyre you fit, (unless the manufacturer has stated otherwise as some different compounds of rubber use dif pressures to aid warming up etc,) you should always use the factory given pressures.
The leak you have is most likely due to a defect in the rim, i.e a bit of rough paint/powdercoat or corrosion etc. The stretch itself wont cause a leak if they were done properly.
The best way to test is a bowl of soapy water and a syringe. whip the wheel off, fill the edge of the rim with the water and look for the bubbles. then flip it and check for them again. Mate had this with a mini, turns out the tyre fitter had left some stickers on the tyres and they were stopping the tyre seating properly.
Jon.
The leak is most likely because bead sealant wasn't used. Yes its possible to get no leaks simply with a tyre & wheel, but it needs a very smooth (almost new) rim and typically tyre fitters use the sealant because they fit tyres to rims which aren't new, etc.
Tyres
I am running the same MIM wheel and would like to fit stretched tyres so I can lower the car more with no rubbing.
Which size and make tyre have you used as they look good.
Unfortunately i cant help with your problem. But was wondering the size of your wheels, offsets etc and what tyres you are using. Any spacers?
This is the exact look i am after!
David
MK1 Golf - 1.3l Driver
MK1 Golf - 1.8 GTI (Build Thread - Here)
abfmk1 said
Fitting a stretched tyre to avoid rubbing is a bit silly when the correct sized rim for that tyre wouldnt rub either.
Yeah but (apparently) fitting the correct tyre to the correct rim, just doesn't look good!!! Strange world, huh.
Why do you think something which looks obviously wrong and has safety implications, looks good? What's so wrong about the "look" of a correctly sized tyre on a correctly sized wheel?
i have read LOADS of people say how they shouldn't do it cos its dangerous but i read on a police site once that they havnt actually had an incident where the stretch was to blame..
just food for thought
ps, i kinda like the stretch look done alot of research on it myself but not gonna delve any deeper lol
booze and boredom, the greatest mix
mixerman said
just to throw a bit into the mix… has anyone had any actual problems with stretched tyres coming off the rims?
That's a good point. The actual safety isn't quantified. The problem is that tyre manufacturers quote a range of wheel rim widths deemed acceptable to mount a particular size tyre on. If you go against tyre manufacturer's guidelines, then it opens the door to "DANGEROUS" interpretation according to law (Construction and Use regs).
The main problem is the bead simply cannot sit properly in the tyre rim, due to the geometry of the two items (which allows fitting in normal circumstances) being wrong due to the stretch of the sidewall.
Remember though, that the grip level of a tyre is from the tread contact with the road, not from the width of the rim its mounted to. So its easy to see that it cannot be any SAFER.
If you do a search, there's plenty of other threads on it. On one of them, web links were made to the EU regs, which definatively proved it was illegal.
i can see why people do it so they fit in
hell ive got a 20vt in my car but how many 20vt mk1s have a towbar? lol
its all down to the personal preference if you want strech them do it but remember its your choice search for the facts and make your own mind up dont follow the croud
i'm happy to go a couple of sizes down but no more, i.e 165 on a 6j rim, but not much more.
it also depends on the profile. the taller the profile the less chance of them coming off. it's coz people try to go too low, i.e 165/50/15 on a 7j rim, which means there isn't much space before you hit the rim. there was a formula going around at one point, which worked out the best tyre for performance.
It worked by working out the triangulation of the stretch, to find the point where structural integrity/wall rigidity were balanced. That way the tyre didn't collapse and the sidewall had enough give not to pop off.
Tbf it was close to 2 sizes and 1 profile higher i think, i.e
original 195/50-15, safest stretch was 165/55(or 60)-15
so i small stretch. the rise in sidewall height is what most people ignore.
Jon.
http://forums.motester.co.uk/forum3/1487.html
