New head fitted but still sounds like a diesel :o(
your problem
Just want some advice about the light and oil etc… sorry to be a pain and I imagine most people on here have felt like you take a step forward and 20 back… going nowhere. :dontknow:
Cheers lad.
good luck with finding the problem
have you seen this excellant guide for setting/checking the timing
The Mk1 Golf Owners Club
baz.
have you fitted the splash gaurd back onto the car , its because you must have hydraulic tappets which requires the OIL to be directed correctly.
baz
I started this post
thanks again
Paul
v
"Grolly" said
Alrite Baz, thanks for all your help and the link to set you timing which is perfect and very well discribed, On Monday I dropped the oil and removed the sump, removed the oil pump and cleaned it all then put back together, then put som semi synth 15/40 oil in but didn't make much change to the sound, last night I set the cam timing which I must say was chuffed, I managed to get everything set up without moving anything all was set TCD, there is still a slight tappet noise but it's alot smoother and it does get better after a few miles I guess this is down to the age/milage, going to do the ignition timing tonight so watch this space. I must say after about 15/20 mins driving the oil light flikers on when at idle not sure what this is….. any ideas ????
im still favouring the oil pump
1991 mk2 golf ryder (deceased)
1983 mk1 golf 1.8 Gti Mars Red (stripped)
1987 mk1 caddy 1.6d Matte Black (deceased)
1990 mk2 golf 1.8 8v Gti Tornado Red (sold)
Now car-less and looking for a long term ride.
Thanks guys for all your help.
