16v conversion wiring using both fuse boxs???
check the black wire to the isv control unit gets 12v with the ignition on
could do a quick bodge test, run 2 wires from 2 pin plug behind fusebox direct to isv and see if it buzzes when ign switched on. if it does you know the issue is between there and engine bay plug
thanks ade
TCI-H unit - testing
1 The switch unit is located in the left-hand side of the plenum chamber beneath a plastic cover. The ignition coil should be in good condition before making this test.
2 Depress the wire clip and pull the connector from the switch unit.
3 Connect a voltmeter between terminals 4 and 2 on the connector then switch on the ignition and check that battery voltage is available. Switch off the ignition.
4 Using an ohmmeter, check that there is continuity between terminal 1 on the connector and terminal 1 on the coil.
5 Refit the connector to the switch unit, then connect a voltmeter across the low tension terminals on the coil.
6 Release the spring and pull the connector from the control unit, then switch on the ignition. Check that initially a reading of 2 volts is registered on the voltmeter, dropping to zero after one to two seconds. If this is not the case, renew the switch unit and also if necessary, the ignition coil.
7 Using a temporary length of wire, briefly earth terminal 12 on the connector. The voltage should rise to at least 2 volts. If this is not the case, renew the switch unit.
ECU - testing
1 Test the TCI unit before checking the control unit.
2 Release the spring and pull the connector from the control unit located in the right-hand side of the plenum chamber.
3 Switch on the ignition, then use a voltmeter to check that battery voltage is available between terminals 3 and 5 on the connector.
4 Check also that battery voltage is available between terminals 6 and 3, then operate the throttle valve switch and check that the voltage drops to zero. Switch off the ignition.
5 Using an ohmmeter, measure the resistance between the connector terminals 1 to 3. These are the temperature sender terminals and the resistance varies according to the coolant temperature.
6 Press the clip and pull the connector from the side of the distributor. Connect the voltmeter to the two outer terminals of the connector, then switch on the ignition. A reading of 5 volts should be registered. Switch off the ignition.
Hall Sender - testing
Note: A digital multi-meter should be used for testing. Do not use a test lamp
1. Release the lead connector from the Hall sender unit. Check the voltage supply to the sender unit by connecting a multi-meter between pin 1 and 3 of the hall sender plug, then switch on the ignition. A minimum reading of 5 volts should be indicated, if not check the FEI control unit and wiring.
2. To check the signal from the Hall sender unit, slide the rubber grommet away from the sender plug and with the plug connected, attach the diode test light to its centre and outer (brown/white) terminals. Operate the starter motor and check that the LED is seen to flicker. If it does not, the Hall sender unit is at fault and must be renewed.
switch unit.
3 Disconnect the multi-plug from the switch unit and connect a voltmeter between terminals 4 and 2.
4 Switch on the ignition and check that battery voltage, or slightly less, is available. If
not, there is an open-circuit in the supply wires.
5 Switch off the ignition and reconnect the multi-plug to the switch unit.
6 Pull the multi-plug from the Hall sender on the side of the distributor, then connect a voltmeter across the +ve and -ve terminals on the coil.
7 Switch on the ignition and check that there is initially 2 volts, dropping to zero after 1 to 2 seconds. If this is not the case, renew the switch unit and coil.
8 Using a length of wire, earth the centre terminal of the distributor multi-plug briefly. The voltage should rise to at least 2 volts. If not, there is an open-circuit or the switch unit is faulty.
9 Switch off the ignition and connect the voltmeter across the outer terminals of the distributor multi-plug.
10 Switch on the ignition and check that 5 volts is registered on the voltmeter.
11 If a fault still exists, renew the switch unit.
12 Switch off the ignition, remove the voltmeter and reconnect the distributor multi-plug.
Hall sensor:
1 Check that the ignition system wiring and plugs are fitted correctly.
2 The coil and TCI-H unit must both be in good condition.
3 Pull the HT lead from the centre of the distributor cap and earth it to the engine or
bodywork.
4 Pull back the rubber boot from the switch unit and connect a voltmeter between terminals 6 and 3.
5 Switch on the ignition and turn the engine by hand in its normal direction of rotation. The voltage should alternate from between 0 and a minimum of 2 volts. If not, the sender is faulty and must be renewed.
