Calling all professional painters - attempting DIY full car
To be honest, that was my last mk1 that i had to let go nearly 3 years ago as i had nowhere to keep it.
Im pleased to say that i have recently got another and have started it all again, with plans for the bay to end up smoother still and its coming along ok so far.
Am going away for a week from tonight though so will be on hold for a short while.
Regarding clips and tabs etc..
I was going to and again will be using 'P' clips which you screw in wherever needs be. And being a carbed 16v going in, theres alot less wires and such required anyway
Stick with it and you wont regret it in the end :clap:
Also means you can do the job quicker.
Couldn't face working on the turrets again. Think I will just remove the sealer alltogether.
Decided to start on the lower half, by the driverside steering rack mount.
Before
IMG_6155 by dherajdagar, on Flickr
IMG_6157 by dherajdagar, on Flickr
IMG_6158 by dherajdagar, on Flickr
During
IMG_6159 by dherajdagar, on Flickr
After
IMG_6167 by dherajdagar, on Flickr
IMG_6168 by dherajdagar, on Flickr
IMG_6166 by dherajdagar, on Flickr
IMG_6163 by dherajdagar, on Flickr
Applied Dinitrol Rust Converter and left overnight
IMG_6175 by dherajdagar, on Flickr
Seamsealer followed by more expoxy mastic tomorrow.
Current MK1 rebuild elapsed time - 15 years and counting…
Is it normal to clean and paint bits of your car that will never be seen?
Not-so-new addition - 1996 MK1 Citi Golf (off the road for 4 years… and counting)
Whent to the car and saw this:
IMG_6176 by dherajdagar, on Flickr
IMG_6177 by dherajdagar, on Flickr
IMG_6178 by dherajdagar, on Flickr
Will have to grind it all back to metal. :angry: Anyone know how this happened? I haven't done anything different to what i have done previously. Iwonder if I needed to apply more thickly.
Will probablly user Metal Ready before applying the Epoxy:
IMG_6179 by dherajdagar, on Flickr
On my engine block I left it on and painted straight over it with POR-15 engine enamel. Planing to to the same here but paintover with epoxy. Anyone able to clarify the instructions
What welder did you get in the end?
'91 Clipper Cabby
'02 Mk4 Tdi Estate
'67 Riley Elf
'79 Mini Clubman estate
'02 Mk4 Tdi Estate
'67 Riley Elf
This website
http://www.theminiforum.co.uk/forums/topic/27741-21-page-guide-telling-you-how-to-prep-and-re-spray/
Says:
Metal Conditioning
After a surface has been completely stripped of paint, primer, and plastic fillers, the next step is metal conditioning. On bare metal, rust forms quickly. It is important to clean off this surface rust and be sure the surface is chemically clean. To etch the surface for better paint adhesion, use metal conditioner. I use POR 15 Metal ready, it cleans light surface rust and leaves a zinc coat on the metal surface. The metal should then be sprayed with a light coat of primer to prevent rust. Improper use of metal conditioner can cause paint failure later. Primer is porous so will not prevent rust in wet/damp conditions.
Anyway, ordered the Clarke 160tm in the end. Should be delivered some time this week. Will have to get the gas though.
So here are the shots of the lower bit near the steering rack which I had to re-grind.
Bare metal:
I cleaned up the hole which the fuel pipes go through. It was a but nobbly so I got the dremel out. A bit OCD but…
Tried the Metal Ready:
Seam sealer applied:
Epoxy applied:
Near side lower area near the rack mount, before:
Bare metaled:
Epoxy mastic applied:
Seam sealer applied (to be over painted with more epoxy):
More grinding to bare metal on the bulkhead:
Applied several coats of Dinitrol in the hear to reach area:
Same for the other side of the bulkhead:
All painted with epoxy mastic:
Determined to get the most awkward areas sorted as I really want to get the car on a spit next week to do the underside Doing this takes ages and is a pig of a job but everyone says the prep is the most important thing. The last think I want is to get top paint bubbling after a while
Still need to flatten the spot welds and a little raised lip:
More tomorrow…
Before:
Removal of underseal:
Bare metal:
Spot welds before:
Spot welds after a bit of Dremmel action:
Prior to epoxy paint:
Painted
The rear bar of the spit also required mods. Was going to start the rear but found that the read mounts were filthy so decided to start cleaning them!
Also did another layer of epoxy on some parts.
After:
Down to bare metal and then protected with Dinitrol:
