Owned it for one week and headgasket has gone
COTM Team
COTM Team
Head bolts i do in order:-
Stage 1 - 29
Stage 2 - 44
Stage 3 - 47
Then i do quarter of turn last
Pete :wink:
so waiting for gasket kit from eurocarparts stating to clean block (any good tips for this) also taking exhaust and inlet manifolds off to renew the gaskets on these as they are obviously past their best…………..
will get the head to the machine shop this week for a pressure test and skim…… fingers crossed it will be ok……. do you have to remove the exhaust valves to get the head skimmed???
simply removed heads, being careful taking time to remove gasket stuck to head, took few hours.
in order to get smooth surface on bottom end and botom of head i simply used the finest wet and dry and gently rub everywhere to surface smooth, job a good un.
If you have patience and want to make sure it done right, spend a good few hours cleaning up.
Here's mine after cleaning down
Pete
COTM Team
Pete :wink:
P.S Im a Him
cheers for your Help by the way
Matt
This is only my opinion but if your head cleans up and looks as good as Pedders I wouldn't bother to have it skimmed. When I did mine a couple of months ago the piston in No1 looked cleaner than the others and that was the one with the water leak, the gasket had deteriorated badly but the head was fine, it runs perfectly now. As far as I know you only have to remove the cam and the water flanges if you do have it skimmed.
Nice one ceder I live only a few miles from west cornwall engine services so will bite the bullet and go for the pressure test and skim I am tempted just to clean and reassemble but need the ressurance that the head is as good as it can be……
Have been rubbish with my pics will try and get some up………. anyone know where i can get some exhaust manifold studs????
was all going so well
head cleaned all new gaskets exhaust inlet etc all torqued up head back on block new bolts all torqued up happy dayz any way i go to put back on cambelt was only changed a few months ago so all i did was undo the tensioner and slip the belt of the camshaft pulley……. anyway for some reason the whilst putting cover back on etc cambelt gets damaged no bother i think ill change it so i try and get the lower cover off then relise that i need to remove the pulleys below……..How on earth do they come off the water pump one has a strange looking bolt in the middle and thr33 allen head bolts around the crankshaft pulley also has allen head bolts which are all on the verge of rounding off anyway in my attempts to remopve pulley ive throwm the engine off timing god knows what is happening where………… help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I need to get the cover off and then set the engine correctly timing wise….. ive got a haynes but all this TDC buisness is chinese to me :redfaced: :redfaced:
