Audi ABK on DX Head?
I will no doubt keep the thread live for the duration until its in the car and running, so watch this space!
Thanks for all your help so far guys…
"Never Knowingly Understood"
'84 Mk1 Golf GTi Campaign
by the looks of things…gearbox would be fine, the motor a clean fit if you are lucky as it's taller, what about management or mp9 with a 2lt map….any ideas
I would personally fit it using MK2 GTI digifant managment and a MK1/2 head. that way you can use the existing 2E distributor and you dont have to mess about with lambda probe fitting or anything like that. plus using digifant managment means you dont need to mess with the wur, or any of the k-jet specific lines etc can use lower pressure rubber lines and EFI pump. under car lines id go with plastic ones from a MK2 Golf or MK3 Polo, fit lift pump + reservoir from rocco/cabby/mk3 polo, main pump from MK3 Polo GT/G40 or mk1 gti pump with barbed banjo adaptor.
I've just put up loads of info about the fuel setup in the fueling section as well
