Body Filler! what do you advise
(In Topic #123398)
which is the best filler to buy which is the best to sand and get a good finish
any help!
If it's ground back properly you wont need any!!
I find a can of bodyfill high build works better than any filler!!!
JOn.
photos will explian more
There is always the old school option of leading, but you wont find many people that will do that cause of the risk of lead poisoning!
1981 1600 gti was silver now mars red!!
<a href="golfsig.jpg picture by barty2 - Photobucket"><img src="http://i286.photobucket.com/albums/ll82/barty2/golfsig.jpg" border="0" alt="Photobucket"></a>
custom sparying, if you live near blackpool! i would let you take charge of my golf
thank you!
ohh any change
after market wings hard to fit is it wise cut bit of back to make them fit, or any techniques
if somebody did the arches and they're sh*te take it back and make them get it right, or don't pay for it!!!!!
I find most garages haven't a clue about bodywork, they tack and fill.
I was working on my mates mini the other week, which wasn't good at the back and in the inner arch. His grandad, who's family has been in the business for pretty much 100 years (seriously, first garage between lincoln and skeg in the early 1900s lol) told us, Just leave the rust and plat it, wont make any difference. Also reconned we shouldn't be doing it tack-at-a-time and that seam welding and grinding back wouldn't distort the thin 80's british steel…
I'm a welder fabricator and it only warps if too much heat is put in at once!!!
Sounds like you got ripped off to be fair.
Jon.
There are of course some who create massive wobbly canyons and load them full of filler…
Unfortunately nowadays a lot of shops go for the latter option which is sad. I've seen a few "totally restored" cars that are loaded with filler all over and they were done by professionals. Skip's mini is a prime example as the filler that his esteemed father put into it has all started to crack and split out after bairly 3months of daily use.
Jon.
I don't think anyone is that good at welding/grinding repairs on car panels that no filler would be used anywhere! 8O Maybe if you had loads of time you could get there, but I'm sure it would cost far more in time and money in the long run.
Minimal use is the best way for sure, using high build primer is a long way round of achiving the same result.
My drivers rear wheel arch is full of the stuff, god knows why, but that certainly hadn't cracked out, it's taken some serious effort to get rid of it!
Most people on here are enthusiasts, not pro's, so the original question was a good one!
I've certainly learned a bit from the bodyshop guys! Thanks
Projekt Frustration :
White 1991 Clipper. Lowered over polished zender rims, Single 40 dellorto on lynx manifold, kent cam, full stainless 'zorst / manifold, powerflex bushed and braced. Not the fastest car, but sounds super nice!
Still going after 12 years… never said it was a quick fix! Time is not my friend.
