Black '82 GTI. Resurrection.
Can't wait to get it fitted properly, and get on with the rest of it know
So started on this bit just below the drivers side rear window.
Then on to the outer skin
A quick smidge of filler and it should be OK
Thanks Gary, big project it may be, but I'm enjoying it so far, which is all that mattersGaryGTi83 said
Just read through your project so far mate.
Big Gratz for taking this project on. Myself i have the horrible sunroof syndrome but in fairness yours looks the bigger project.
Great Work so far mate. Looking forward to seeing this done
It's got 3 separate bits of rot, but the rest is so solid, I don't want to replace the whole thing, here the pic of it before.
and here's the first repair, at the back end of the sill.
on to a tiny plate about halfway along the sill.
Then the 'orrid bit of rot at the front end, at the bottom of the A-post. This could be good, or it could be a right mess :roll:
And the finished repair, I like this so much I took pictures from several angles
There is still a bit of weld left right in the corner, but after about an hour of hand filing, I had enough Lazy I know
On to this bit at the front of the sill/bottom of the A pillar/floor :roll:
It's only a small bit of rot, but it's made up of 6 separate pieces, so took ages.
Started by making a plate to repair the front box section bit
Also made a piece to repair the sill, but didn't take a pic, so next cut out the rot and repaired the edge of the floor and the inner sill.
Then welded the front box section up and ground the welds back
and refitted the jig fixing thingy.
didn't take enough pics so this is how i've left it today
Just need to grind back those last few welds, and another bit is done
Alex
1979 S1 MK1 Golf L FOR SALE! http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=101471
1970 VW Beetle 1600 Twin 34 ICT\'s - Betty
1973 Marathon Beetle - The Moll\'s
My Build Thread
Thanks, As the old uns used to say, "There's no such word as can't" It's taken me a while though.Phataz1 said
Brilliant repair work 8) It's something which I still need to overcome the initial "can't be fixed" worries for
Thanks Alex, It's not out of the woods yet Your right though, probably would have made more sense to just break it, but I'm enjoying the challenge.TwoToneAlex said
Nice bit of fabrication there, glad you've saved this one, as I fear it would have ended up dead or bodged without you
Alex
Thanks Al, just a DIYer, not even a talented oneAL_Mk1 said
Very nice repair work. You do this for a living or just a talented DIYer?
Cut out the rot and repaired the inner arch lip
Not enough pics again, but here it is welded in and ground back, with a splash of zinc primer
A week or so more of this, then the Escort is coming out for the summer, so not much will get done on the Golf for a while, if I could just win the lottery, I would have plenty of time for both
Finally going to attach the roof next weekend
