back in black
back in black
the painted floor pan
picked up some vectra 1.8 16v callipers just need to finish cleaning them and a lick off paint and new seals then get them bolted up
days few before rubber once again touches ground
rear beam all back together and painted up looks good superflex bushes fitted
then bolted back up to the car,
assembled the front end, again all painted with superflex bushes
still looking for the right coilovers at the mo so kept the old ones on for now, the engine bay is on the list v soon
hopefullly back on its rubber next week.
after about 2 hours of discussion and a bit of trial and error finally managed to get the the car down off of the jig you really do need more than two people to do this safely.but hey hoe a few strained arms and faces later rubber on the ground
the pattern panel fits really well considering not much to do there, thank god, same with the rear bottom vallence simply cut tack fettle and jobs a good en, i hope. find out tomorrow.
Rich
ok so the rear wasnt as easy as i thought but eventually got it on a lot os messing around, quite a few photos some better than others camera flash is not working now.
all done rubbed down and primered up now need a final look at as the primer has revealed some imperfections so will sort it in the next few days more pics to come, will soon be moving on to the front panel sometime this week.
My Build Thread
All paint by the way was done by hand with rattle cans from halfords, (satin black) and different grades of wet and dry then polish compound and finally polish, ALL BY HAND well and my little orbital sander.
Headlining, well the less said about this the better apart from get someone to help and cut little and often will have to redo this next year.
Ok with the paint sorted time for the engine, never actually intended to tackle this but thought sod it might aswell have a go.
port polished head.
well as best as i could with a multi dremel and the limited bits i had.
next was a phone call to bogg bro, carbs all cleaned and jetted, new mani
ive lost pics of the bottom end being done, so next stage was fitting it, this was a hell of a job by myself even with the crane, at one point i thought i was playing twister with the car and well and truly got beat but after a lot of sweat and shouting at the car engine and crane they eventually played ball, i did however mark the bay quite a lot luckiliy the bay will be being re-done next summer,
now had a little issue with bogg bro water pipe fouling the oil dip stick and also didnt fit the rubber pipes, bit dissapointed with it really but a bit off heat and a breacker bar carefully bent it over and out the way all good now.
dash loom had to be sorted out so took inside and sat and followed every single wire from start to finish.
the engine bay was relativly simple with a bit of research lol.
more soon
Hairyarse said
Nice work chap, like the paint with rattle cans - good result - you must have a lot of patience!
cheers mate, yeah takes a while to get it right the paint was done this summer but with all the moving around the garage and knocking into some of the pannels will need looking at next year got a compressor now so ill give it a go with proper stuff.
Jinjar said
Very impressed!! More with your get on with it approach despite no "mechanical training". Very nice indeed, I've been searching high and low for a garage to do just the same, although I doubt ill tackle the welding though!!
Lol it was one thing i never expected untill it was stripped was going to pay some one but again got a few mates who weld asked them for advice, went and got a cheap welder and just had a go however i would definately invest in a decent welder dosent have to a big one, mine kept over heating and shutting down, could take hours just to get a relativly small bit done
my top tip for welding is it should sound like bacon sizzling in a pan thats what i got told, only time will tell now if mine is any good.
Long story short- after having the head off 4 times (each time new bolts gasket) it turned out that the bottom end had had a right bodge job done on it the one thing i nev er checked as the lad i bought it off said he had rebuilt it and seemed at the time he knew what he was doing obviously not. the bottom end bearings were shafted and one of the camrod connectors had not been bolted up because the WOOD bolt being used didnt fit
any how almost chucked it all at this point had had just about enough of the whole thing, nothing is easy when you dont know what your doing lol.
any way had a spare engine 300 miles away sat in my garage at home, so off i went one weekend to try and see what i could managed to get done in 2 days
not bad i think for 2 days work, and that includes traveling from plymouth to nottingham to get the engine and then back down again to get it in, starting to get the hang of it. The engine is a standard 1.8 16v this will be up for sale asoon as ive sorted my 9a out, it will come complete with r6 carbs and manifold and maybe even the exhaust mani if i get a another one for the 9a, so whatch out for that around about easter if not before.
all working, had a small air lock sorted that out , and had to change one of the temp senders as it was the issue with the gauge, all timed up and good to go, will get it fulled tuned once its mot'd
small chrome bumpers came in the post chucked them on with the old brackets which fit fine, and decided to put of extra sound proofing in. just used some laminate floor stuff mega light and will help a little.
thats about it now untill the new year and i get back to it, got some vdo gauges to put it and try and find some gti seats, got some tombstones that i made brackets for they sit a little high for my liking and really gti seats are amazing,
oh and the bonnet is not staying silver had a small accident a few months back and havent had time to get it sorted but that will be being re done. and maybe some banded 14 inch steelies, 7 front 8 rear, and that will be that untill end of next summer when it comes in for a proper body shop session. will get videos up as soon as i can find my camera which i think is in the glove box, about 300 miles away so till the new year.
im yet to get them on the rolling road to get set up properly but my mate has exactly the same set up and his is mental pulls like hell, and instant, hopefullyget set up next month when i can get it booked in, but it goes ok as is at the mo and that is set up from bogg bros so there set up is close just needs tweaking.supersport2 said
How are the carbs going? Noticed any difference?
should be getting new exhaust system this week so get that on first.
