mk1 tintop with oettinger
i still have not confimed if this engine is the real deal yet, this is the plate fitted over the engine number if anyone knows what it means?
will find out at midday how long the fail sheet is
EDIT, failed on a couple of bulbs and a steering rack boot, im happy with that, getting them to adjust the fuelling too as its running too lean but it comes home on tuesday, road legal :wink:
It refused to start after a short run, its running as rough as could be displaying all the symptoms of rust in the fuel
Going to dip the tank this weekend to check but I doubt its going to useable for a while.
Karl
well there is rust in the tank, filler neck was worse than i expected.
theres a new neck on there now, the tank has been drained and when i next have a bit of time free im going to pull the tank off to properly clean it out,
put the gti arches on the drivers side too while the tank was draining, im going to keep them on there as i think it looks better.
been stupidly busy with work and other stuff, but in the boxes of bits in the garage i have found a metering head, injectors with the braided hoses, a warm up reg and an accumilator so at least i have most of what i need, i think i will go the whole hog with this and change the fuel lines too as then at least i will know its all good. just need some free time!
typical me, MOT, tax and insure it then just leave it in the garage
i was tempted to rip the tank off the breaker and use that but a new one should be a lot easier,
its done a total of 4 miles since its been taxed, mot'd and insured! Karl
im hoping to bring it to the AGM so i dont have to rock up in the wifes mk4
http://s27.photobucket.com/albums/c160/sweetmk1dub/?action=view&current=VIDEO0012.mp4
still not quite right though so a little more fettling needed, i have a funny feeling the injectors are fooked, brakes need bleeding and a few electrical bits to do, oil pressure buzzer is going mad now too,
slow progress is better than no progress
she had her oettinger lump back then too so its not gone in recently
they are setting up the mixture for me too.
im bringing it to edition this year if anyone fancies a nosey.
Karl
will bring it to the midlands meet on wednesday
sweetmk1dub said
well as its been 6 months its due an update, new tank on there and the back end has been put back together and ive just bought me these
hi what are these for if you dont mind me asking are they braided hses for your brake lines.
where did you get them from as well please Many thanks harry
Mk1 golf GTI 1.8 - bargain buy
Suzuki Samurai - 4WD 1.7 TD Conversion - Off roader
thanks as i cut mine in halfsweetmk1dub said
Harry, they are new fuel lines as the original ones were clogged up with rust, available from crazyquiffs
lovely car as well
T5. Corrado VR6. Mk2 G60. MK1 Cab
