Damn I need help
(In Topic #120427)
Damn I need help
oil pressure wires are yellow and blue, high pressure sensor is white and in the filter housing, low pressure is brown or blue the side of the head. low pressure switch is what controls oil light at idle/engine off
It wouldn't be so bad if the evenings wernt so dark,bring on the summer
I'm having a problem with the wires that i'm left with…
There's a wire running from a loom with three wires coming from it. One black running to a round thing on the right of carb,another is red running somwhere underneath the carb,and the third is blue with a red stripe and a female spade connector-this is one of the spare wires currently unconnected.
Second spare wire is under carb on the left there's a brown earth to the rockercover and a black wire with a female spade connector which is unconnected.
There is also a two pin socket left on a round thing with a rod coming out of it on left of carb and another identical socket just behind and above it,I only have two spare wires!!
Car was a 1.6 now has 1.8 with a 1.8 carb with auto choke.it had auto choke when it was a 1.6 also
on the opposite side of the carb there is the TTV and the overrun valve. then on the front there is the carb heater.
there should be 3 sensors on the coolant hoses, black for the dash gauge, a grey one for the autochoke and a red fr the inlet heater. Later engines have all 3 in the coolant flange on the front of the head, early ones have a inline sensor holder thing round the side of the head in a coolant hose.
If you check for continuity between the single pin connectors and the temp sensor plugs you'll figure out which is which
the ttv and overrun valve both have a 2 pin plug which is ign live, and the heater on the front also has an ign live. then there is an earth from the carb to the head which provides an earth for the autochoke and the carb heater
it will rev high with these items disconnected becausde the ttv/overrun control the 3/4 point unit
Sorry if I'm being thick
cant do that with the coolant ones, the black one is dash temp so it should have a red/yel wire to 1 pin and the other just earth.
With the red & grey ones what you should do is use a relay to send power to 1 pin of each sensor and run the other pin to the carb heater or autochoke matching the wire colour up above.
If you dont have these sensors then You'll need to add them ideally, though you might get away without. Try wiring up the ttv/overrun and carb heater first and see how that goes
hence why there is a switch which cuts out the choke heater once coolant gets up to a certain temp. there is another thermoswitch for the inlet heater, which does the same thing but for the inlet heater.
you can rule it out simply by putting an ign live feed on the choke heater (assuming its ok!) if its better you know you need to sort the choke heater feed.
to check the heater you need to use a multimeter, put 1 probe on the spade for the choke heater, the other on the body of the autochoke.
also check for continuity between the battery -ve and the carb, if not the earth from carb to roccker cover is poor/missing
