Heated seats
Heated seats
Its still in the garage at the moment its needed a new clutch and gear box and i had a new engine belt on to make sure as dont when it was last replaced ! also the body work although no rust any where needs some spraying
Its crazy what people do over the years to cars isnt it ?
i had to locate all the correct badges , alloys , gear knob ( mine had a man city gear knob ) that came off straight away!
so its costing me at the moment but hopefully i can get it back to its glory i think the seat will be the last job
jay
Jay
1990 - MK1 GOLF CADDY PICKUP | 1980 - MINI GT 1275 | 2005 - RENAULT TRAFIC CAMPER
pm me if so please
jay
Jay
pm funkstar
or ask shamstar on his post
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=86770&postdays=0&postorder=asc&highlight=breaking+rivage&start=90
or put a wanted post up
good luck 8)
cheers for your help
jay
Jay
http://forums.vwvortex.com/member.php?297437
he lives in canadia so has access to a lot of heated seat kits. got my mk2 stuff from him. mk1/2/3 kits are all basically the same, only difference is some of the plugs changed shape over the years, and obviously the dash switch is a different shape. a corrado/passat switch might work, its same orientation as a mk1 switch, though i guess its not quite the right shape to fit the mk1 dah hole…
Heated Seat element
Does anyone know if there are any heated seat elements on the market that fit the original seats and wiring conectors in a Rivage???
Long shot.
Thanks for any help/advice.
if you can get the right spec thermistor you can convert the aftermarket stuff to work in a mk1 vag kit, or if you had some scrap heat panels you could chop it out of
heated seats
I just need the seat heating pads with the correct connector.
Jay
Jay
What do i need to look out for in regards to the seat heat elements , what other models are the same ?
is there a fuse i can check what number ?
Jay
heated seats
'Mario' the guy on E38 is a cool guy, the only problem is the connectors look like Mk3, so if i use them i will need to alter my factory loom connector.
I did however manage to get my loom/switch working after ordering the stuff, so i now have power to the connector under each seat. I may get some carbon pads and just alter my connector, just unsure if my 'variable' heat dash switch will work as i don't want just 'on' or 'off'
Relays and wiring for sale if anyone is interested £50 posted. May also sell the pads (3 only, 2 backs 1 seat, all second hand, untested) £75 the lot (with relays and wiring) posted.
