Heated seats
(In Topic #120325)
Heated seats
I'm considering retro-fitting heated seat elements into my seats. A colleague has a Z4 with heated leather interior and the heated seats keep you really nice and warm when the roof is down. I have a wind deflector in the car but still find that the heater alone doesn't keep the cab area nice and warm when the hood is down.
I have seen aftermarket kits on ebay that look to be good quality and I've also seen a build thread on Edition 38 with a kit fitted into Edition 1 G60 Recaro's.
Can anyone with a Rivage with heated seats post up a picture of the switch/controls. The aftermarket kits switches look fairly OE, but I'd like to see what VW supplied and where they located the switch as standard before going aftermarket.
I think it will be a nice addition to the car, allowing it to be used with the top down on these cold yet sunny days we have been having recently. My main worry is wrecking my seats!
Has anyone else considered or done this?
been thinking about putting one of the aftermarket heated seat kit in since I changed my daily. That has and its really toasty, really impressed. Which kits are you thinking about in particular. They seem to come and go on fleabay, very few offering the same kit for very long.
One seller had a few kits a couple of weeks back with carbon heaters and occupancy sensors but seller dissappeared after a few weeks, which is normally a bad sign.
been thinking about these
ebay heated seats
ebay heated seats
1988 1.8 carb Golf Clipper
I would love to have heated seats but would be inclined not to trust my cabbys battery set-up. Would also worry about my 24 year old seat material, which is a little threadbare!
They're the one's I've been looking at djheap. Waeco seems to be a good brand for car electricals/accessories and the switches look quite OE, they also do an add-on thermostatic type switch (although it's not as neat looking as the on-off switch).
I know what you mean about the seat material neo, mine are in good condition but I've only experienced heated seats when they are leather (usually freezing on a morning!) and don't want to ruin the seat fabric. I'd be gutted if I fitted the kits, switched them on and melted the seat!
Here's the thread I keep looking back to on Edition 38:
Recaro seat strip down
Has anyone stripped down a fabric Rivage seat? Do they have a thin foam layer between the heater element and the seat cloth?
drop this guy a pm, he lives in canada where heated seats are common as muck, so can get hold of complete VAG kits for most models. got my MK2 Golf setup from him. if you want to know what MK1 switches look like, open your owners manual
http://forums.vwvortex.com/zerouser?cmd=viewprofile&id=297437
Cheers!
Good call :doh:
guess its possible to install a house radiator in the car to keep you warm
this will work but only id you cut out the temp sensor unit and splice it into the aftermarket seat base. the VAG setup gets temperature reading so it knows exactly how hot the seats are. if you bypass it with a resistor all you'll get is a constant heat which relates to the resistance you fitted, no adjustability.
the pads are pretty easy to repair, bit of solder and some wire does the trick usually
bouchay… did you check your heated seat relay is still functional? I have just got my passenger side seat working .. my car had previously been leaking badly and the relay had rusted open
I'm pretty sure I checked with a multimeter on the end of the loom where the plug is, and the voltage changed when I moved the switch on the dash. So I presumed that the car end is fine and so the elements must be shot. :dontknow: So where is the relay? Is it in the fuse box? And how do you check it?
Cheers, Bob.
Cheers, Bob.
The relay in inside a bit of sponge in the car fram under the seat. number 8 on the image
I miss my heated seats sooooo much. :O(
That is all.
That is all.
Life in the French Alps: <a href="Le Franco Phoney: All things French in La Clusaz, Annecy and Haute Savoie">www.lefrancophoney.com</a>
Is it poss to fit heated seat set up from a mk3,coz surly they just need 12 volt power to the seat loom????or am i just looking up the wrong tree,i want so bad heated seats........ :redfaced:
just got my new heated seat relay (from canada) £16 delivered .. these are £37 +Vat from vw dealer.
It lives under the carpet within the frame in a bit of sponge under the seat as in the diagram above.. This is the cause of my passenger seat not working. my passenger side used to leak badly from the cabby handles and through the bulk head
found this link about heated seats which I think is useful, but I havent checked the wire colours match.
http://forums.tdiclub.com/showthread.php?t=154510
new…… and old
new…… and old
they are same as mk3, :dontknow:
read the link they all the same then :redfaced:
i think this is whats wrong with mine as my seats dont heat
Jay
1990 - MK1 GOLF CADDY PICKUP | 1980 - MINI GT 1275 | 2005 - RENAULT TRAFIC CAMPER
i have a rivage and in preston if you want to come over and try and figure out whats wrong with yours.. if they both dont work i would expect its the elements..
cheers tony
