here goes (KPV753V)
here goes (KPV753V)
bonnet catch fitted
looking good 8) ?
was that WAR from a ford with the red fuel pipes ?
Do you recommend fitting the enging+box from the bottom ?
The oil cooler is also a different design from my DX as well
baz
peeriehutchie said
the engine fitting just kinda happened that way due to the body already being on stands and the block able to slide in , but the advantage i thought was no chance of scratches and as you can see ive very limited room to move
hi
yeh , if the time comes when my 112 horses needs a need new hoofs im going na go for taking out/in from the bottom as well.
baz
still toilling with the dash wiring
well done on getting her started!
rev counter doesnt work
looks proper old-skool with that dash
did you get your brakes sorted.I cant see past the ezi-bleed kit for bleeding brakes on a mk1 & gaining a firm brake pedal . What i did before adding/wasting brake fluid i pressure tested the braking system using the ezi-bleed kit using just the pressurised air for a couple hours to see if the system pressure dropped.
barry
gettin there :wink:
