B Reg GTI Tin Top
(In Topic #119039)
B Reg GTI Tin Top
The car has also had a 2.0 16v Audi engine fitted with twin weber 45 carburettors and coilovers. First job was to replace the broken alternator and get it chaiging again and I have also replaced the steering wheel with an original 4 button one, thats about it for just now, pics of it today!
Are you putting it back to completely original conditin then or are you keeping the 2 litre in it?
The 45's will sound amazing 8)
another one for the collection, :wink:
If your going for a standard look & are after some seats, I've got a rear bench & some fronts if you want them :dontknow:
Andrew
Old engine removed
Car up on my newest toy
New engine fitted
Also been busy trying to sort out the MFA and also fitted the front spoiler and gave the car a wash, its too dark to take a pic now :x Will be doing more tomorrow as I have had the week off work!
Where did you get the lift from? I NEED one
What was squint though? the lift or the camera?
http://cgi.ebay.co.uk/CAR-LIFT-MID-RISE-SCISSOR-MOBILE_W0QQitemZ330393807113QQcmdZViewItemQQptZLH_DefaultDomain_3?hash=item4ced016909
No more crawling around on the floor for me but I'm low on funds now :cry:
Was thinking about getting one of these at least
Anyway, the engines looking good all painted up. Makes all the difference
Any luck selling the 1.1 btw?
thanks for the engine still not fitted but is painted tho.
Will bring that key around at some point.
fitted a new speedo cable to night to get the speedo working again, MFA works a bit better but the MPG is miles out says 85 MPG Need to have another look at it sometime!
dubhighland said
Looking good allan 8)
Thanks!
Been very busy again with this, its not easy as its my daily driver and the weather being so rubbish. Have now changed the coilovers for shocks and springs with new front top mounts, have also changed the front wheel bearings, bottom ball joints, outer CV joints and wheel bearings. When changing it all over I noticed that the brake pads were getting low so they are next to be replaced. Once all rebuilt I set the camber and the the tracking, its now totally different to drive.
New ball joint and CV joint
New wheel bearing and hub assy getting refitted
2 wheel laser wheel alignment
Also noticed this leaking fuel line
So decided a full set of stainless braided lines from Crazyquiff would be a good idea! Still part of the way through fitting them.
Should be a few more updates if the weather stays good!
Also decided to replace the track rods and ends, so now the steering should feel alot better, old parts vs new parts
