Temp gauge
Temp gauge
the temp sensors on pretty much all VAG engines up to the end of the MK2 production are the same rating, just there are 2 shapes depending on the age/model. earlier models and 16vs use a single pin sensor with a black colar, later models use a 2 pin black sensor. using either sensor makes no difference, just the 2 pin one also requires an earth, the single pin ones earth thru the engine block.
The fact it still does it with sensor off tells you there is a wiring/clocks/level sensor relay fault, or you disconnected the wrong plug
