MK1 Jetta, 2ltr 16v ACE
MK1 Jetta, 16v.... 2.0 ACE bottom end on the cards
Scott
Where did you get it from !?
Also, what size is the original metal line ???
Real golfers don't play with clubs
Gold-mk1 said
Good work, excellent idea with the airline too !
Air line I bought from a local pneumatics specialist, VW used nylon fuel lines on the mk2 16v also on most modern engine fuel lines so I figured it would do for me. Its also alot cheaper than stainless lines and has the same resistance to the elements.
It cost me £12 for 30M, which is a steal, if you warm the ends up in boiling water (sweating) they just push onto the nipples on the accumulator/ Metering head.
As for the existing metal lines on my jetta ? they were about 6mm, on the 16v mk2 their 8mm on my mk1 golf 8mm I think..
Finally started the wiring today, routed the loom for the lights, horn and washer bottle. So later on this week the dash will be coming out to gain better access to the fuse box.
MK1 83 Jetta… 2ltr 16v ACE
MK1 88 caddy pickup 20VT soon
MK2 Golf 90spec 2ltr ABF coming soon
T5 TDI
T5 TDI
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=73039&highlight=
P.S: PM'd
Take one mk1 gti air box…. And Hack
Soldering the larger wires, which were to big for the solder sleeves using the hook method, these were then double shrink sleeved.
And as I left the old girl, nearly there….
T5 TDI
T5 TDI
G60
So tomoz i'm gonna get some new plugs, and check the ignition system, luckilt i have two other coils to try too, hopefully i'll have some better news tomoz.
Few pics of the fuel lines after sweating them on, Lovverly and oem.
T5 TDI
T5 TDI
if you don't check the TCI. that's what stopped mine firing up the other day.
Discovered that my earth was crap to the engine block so we put a jump lead from the neg of the battery to the engine block and the engine span over quicker but its still slow….
changed the spark plugs, the ones I took out looked pretty new but they were black and wet with fuel….. so were getting fuel ( Maybe fuel pressure ?)
Also getting a spark, just need to check the order is correct on dizzy, the ones I took off were changed like for like with the new ones..
So tomorrow the plan is….
New fuel into the tank.
Use my battery from my mk3 derv.
Check leads are correct on dizzy.
If anyone else can recommend things to check, much appreciated
T5 TDI
T5 TDI
Other than the above I just need to finish tinkering with the brake lines then i'll take her for a spin
T5 TDI
T5 TDI
dubassasin said
Well she runs, albeit a tad lumpy but she works woohoo. I'll put the standard exhaust back on this week hopefully it'll be on the restrictive side but it'll do so i can set the timing up so she idles better. then get an exhaust fabbed up and then rolling roaded.
Nice work dude
Well first a video of the problem in question…..
http://www.youtube.com/watch?v=XGvUjcgX5qc
So after stripping off the cam belt and the rest of the gubbins I found the problem…
So I put it all back together again checking that none of the other pulleys rubbed anywhere on the plate….
Fail, the squealing had gone but there was still a rubbing somewhere…… then found the belt was rubbing on the cover plate where it peels off the tensioner…. so I cut that off….
Built it all back up again to check, which left me with this….
http://www.youtube.com/watch?v=AdQAepdS66U
Which makes me a happy bunny :music:…… now to the next problem…
1/ Leaking radiator, one of the fixing slots to the top panel is leaking (nothing i've done) already have a remedy for it.
2/ Leaking rocker cover gasket.
3/ Align gearlinkage… what a bugger.
4/ Bleed brakes.
5/ Replce copper washer on fuel pump to accumulator line.
…….. at the present speed…. I'll be done next month..
T5 TDI
T5 TDI
T5 TDI
T5 TDI
I'll get pics up….soon.
So then came the obligatory "Try it out, see if it works", kinell yes, and that was only n the wet country lanes I pulled back into my unit with the biggest grin.
Still over fueling, any ideas on what that normally is ?
T5 TDI
T5 TDI
T5 TDI
T5 TDI
…. quick pic with the new boots on. Renault turbines. Black of course
But…. I keep looking at these rims and thinking……I wonder….. what if….. Maybe….. ermmm….
T5 TDI
T5 TDI
