fuel pump trouble
(In Topic #114731)
fuel pump trouble
i need to buy a fuel pump for my 1.3 golf engine and was not sure what kind of pressure needed to run the engine propperly,
i have been told that a FACET SOLID STATE fuel pump would be MY best option and they seem quite good value for money
but some are 3bar - 4bar
and others up to 10bar for the GTI
what kind of pressure will i need
its a 1.3, running a single choke, solex carburettor, jetted for a 1.3
<a href="http://s277.photobucket.com/albums/kk54/tamthebam16v/?action=view¤t=05092008653-1.jpg"><img src="http://i277.photobucket.com/albums/kk54/tamthebam16v/05092008653-1.jpg" border="0" alt="Photobucket"></a>
fuel pump
so now i dont know what kind of pressure pump it needs to run at :dontknow:
try a polo gt fuel pump fused and wired to the ignition with a pressure reg (not quite sure what pressure you want to be running though)
keep on dubbing
keep on dubbing
fuel pump trouble
but where do i find one of them, included with the relay (doesent matter bout wiring, got miles of it)
just a small problem, with it being an N model, it has no rev counter, but i am changing the ignition system to a mk2 golf setup so that i can keep my points and apparently there is a rev counter wire with that so would that be suitable or not?
gsf will sell you a suitable relay without a rev limiter:
93592 - ?23.20
fuel pump
so all i need is that
k-jet pump or other pump (facet solid state?????) :dontknow:
and regulator ?????
because of the regulator will the pump be sufficiant to run a carbed 1.3 (standard)
where can i get the regulator and the pump from please
scrappy is out of the question unless components not on mk1 golf
itll pump the right pressure for the carb ( 4 to 7 psi approx) .
Dont use a gti electric pump its capable of 60 or 70 psi if its restricted and itll chuck fuel all over the place.
Have a word with your parts supplier, tell them the car, the year, the engine and size etc.
fuel pump
and i dont have the ECU or the pump so having to use bits and bobs from numerous golfs etc to replace the pump
someone told me that a facet solid state fuel pump, fused and wired into the ignition would be substantial, clearley not
I'd imagine even a later rocco/cabrio injection lift pump would probably work with this setup, just need some kind of fuel reservoir (maybe the setup from the same car as the lift pump?) to prevent fuel starvation thru corners
fuel pump
would this adjustable carb reg be sufficiant
ebay number
120423157549
range of 1-5 psi ???????
i had a look at lift pumps and i came up with simular stuff to a facet pump so would this be alright
ebay number
110392495774
range of 3-4 psi ???????
i cannot find any reservoir's ??
…so i put the relay inside the car, the pump close to the tank, the reservoir???, and the fuel reg anywhere within reach ???
cheers for help mate
fuel pump
final thing then mate, how to i wire up the relay, ie what pin goes where and wiring etc, and would i need to put a fuse inline to protect the relay, if so, where?
cheers again
1 - rev counter input
87 - fuel pump output (fuse this, 20amp)
30 - permanent live
15 - ignition live
31 - earth
as for the ignition system i do have a mk1 electronic ignition loom sat in my garage, but i dont have a suitable vac advance dizzy. only issue is it doesnt have a plug on the hall sensoer wiring,. as i had to nick that for my mates engine when i fitted a mk1 k-jet dizzy to it.
Pins are still there though, you litterally just need a suitable plug houysing that fits your dizzy to pop the pins into
fuel pump
unsure of that comment…..
you have a dizzy but not the terminal housing????
i have a housing from a mk3 polo that is apparently the same
what loom is it i.e…between coil, TCI-H and dizzy or what??
cheers yet again
fuel pump
so will that plug into the 3 pin connention off the mk3 polo 1.3 dizzy or plug into any other suitable dizzy with vacuum advance and weighted dizzy
also it needs to be a 1.3 dizzy like you said in a previous post to me so it it suitable for that with other 1.3 parts like the 1.3 tci-h and the coil?
